I just picked up a nitrous oxide kit from a friend over the weekend. It is a Nitrous Express kit that has only been used a few times. I plan to run a 75 shot on my 4.0 for those long, steep hills where the 4.0 just runs out of power. A number of guys at the shop tell me how dumb I am, and how I will just blow up the motor. Now unfortunately I can not retard my timing so I will run 93 octane to counteract the spray. Is this really that bad of an idea?
Using NOS is going to leave you stranded at the worse possible situation...
Is it a dry or wet setup? most NOS failures are due to lack of fuel, a stock fuel system will not compensate for much nitrous. BTW take video of the first time you use it, i love a good nitrous kaboom! :flipoff2:
99% of people have no idea what there talking about. Nitrous is very safe when used correctly and shot size is kept resonable. Ive run Nitrous on many many things,from atv's to sleds to motorcycles.
No need to retard timming on a small shot. 50-75 shot is a nice boost and will be pretty safe. be sure to use the proper fuel jet and be sure you dont lose fuel presure when spraying.
you start blowing motors when you get greedy and up the shot size and also when you over rev. keep the r'ss in range and rock on ..
If that kit is for your 4.0. A 75 shot will not hurt your motor the computer will sence a lean condition and richen up the mixture durring use. Dont get greedy only use it when you need it. Dont use it with to much durration.
Have Fun. Tell the GUY,s you work with to :flipoff2:
all of these are good points, but no need on a small hit like you are talking about. the full throttle switch in any situation, but other than that just spray away. Nitrous doesnt hurt motors, bad tune ups do. (greediness)
love that quote For a trail rig, I would avoid Nitro like the plague, no mater how safe it is being argued it is. Too many factors in place and a sudden boost to your powertrain could literally tear other thigs up or severely lessen the life of your engine.
From the dumb days of street racing, we saw way too many people misusing or just setting things plain wrong leading to REALLY bad stuff. I would say sell the kit and go with something more uniform like a stroker setup.
If the system is set up correcty there is NO issue with usign NOS. All you are doing is adding additional oxygen (nitrogen) to the combustion process. The typical failure mode for a engine runnig NOS is not having the proper EQR (or air fuel ratio) when injecting the mixture in the intake air system......you torch the cylinder system from higher combustion temps (along with other failure modes that accompany high combustion temps). Good systems will add fuel during the additon of the NOS. Generally, the respose of your stock fuel trim will be too slow to compensate to the addition of nos (this would be for a fuel injected system). If you want to be conservative, make sure you have a fuel mixture richer than MBT (fuel for max torque) and viola, cheap torque via a bottle.
I would NOT bolt the system on and expect to run without any tune, this is asking for trouble.
The problem is, once you spray for the first time...You'll keep doing it. You can say all you want that you'll only use it for steep hills where needed.....But that won't happen.
if a crappy 3.8 v6 can handle a 125 shot i have no doubt that the 4.0 can handle a 75 shot. run a boost a pump. make some test passes and check the plugs after each run changing the fuel pill untill you get a good color on the plug. follow the basic rules, only spray at full throttle and only above 3,000 rpms.
A number of you have mentioned checking spark plugs. What am I looking for? Do I need to add more gap? Keep in mind I will probably on us the nitrous a few times during the wheeling season. I really only plan to use it on those long, steep, muddy hills where I run out of HP. Mr. Hogg knows what I am referring to.
