I am getting ready to build my cage and have been looking at a lot of build threads for ideas. It would be easier if we had one thread for ideas. I do not care what the cage is made of (dom,hrew,pipe) this is not the spot for that disscussion. I am looking for design pictures that will help others build their cage. Also pics of the frame tie ins.
If you have pictures that you stole from some other post or if it is not you cage, I do not care just post the pics for build ideas.
I bought the dom for my cage today. They had 5- 18' sticks of 1.75 x .120 in stock @ $4.05 a foot. I will have to go down and pick it up sometime this week.
I like the cages that have a flat top with an a to c hoop vs side to side.
Is there any reason I should or should not put a side bend in the top of the hoop(the bend just in front of the b post) ? I like the idea of having the cage wider near my head vs running the top straight back from a to c.
Oh wait this is yours!!! Hahahahahahahahahahahahahahahahahahahahahah.....hahahahahahahahahahahaha......hahahahahahahahahahahahahahahaha!!
You have to be shitting me!!! WTF is that front hoop! haha yep you can use a bender to put a huge failure zone in your cage you don't have any corner gussets on anything! no center support in your front or rear roll hoop no diagonal support and I really really don't want to see how its connected to the floor!!! hahahaha
Please please please scrap that cage. I know there's not many off road or fab shops in Santa Fe, but we got tons down here in Albuquerque. My cage was ~$500 out the door, I provided the DOM, and it provided peace of mind.
Same to you if its so sketchy tell me what part of it is. You to idiots don't know shit other than how to spend money and criticize. I hate busting out this card but I'm pretty sure that there is only one of us that has an engineering degree with a background in structural steel and its not you two idiots!
You've been challenged if its scrap show me a week point and i'll show you where you are wrong!
I say floor cause the way you had this thing built I doubt any of the morons standing around had the sense to tie it into the frame!!! hahahahaha Hey I've got an idea lets put em on general 4x4 discussion and see which cage people would rather be in when invloved in a roll!! hahaha
Ok, if you don't want to take my advice, fine, people actually care enough to see you not get hurt. I see you have to call me an idiot, because you're butthurt. It's tied into the frame, 6 point. Knowing that you're from Santa Fe you're probably a ************ anyway.
Happy trails :flipoff2:
You guys do not like each others cage build, and thats fine. I do not want this thread to be about guys name calling, pissing back and forth about their cages. If you do not like something about someones cage, it is ok to point out the weak point, but do not keep bitchin'.
I bought the plans and built my bender, and I bent my first tube last night. I have never used a bender before, but I have found a lot of good info on this sight that made it pretty easy (stressful, but easy). I thought the easiest way to lay everything out was on a 4x8 sheet of plywood, and follow the lay out instructions from tube bending 101 in the tech section. My digital angle finder made it very easy to make two identical hoops. The first hoop took a little longer to make, but I used a speed square to get my angles off the plywood. I wrote down all the angles from the first hoop and bent the second one exactly to the same degrees on the digital angle finder.
Lesson learned with the digital angle finder: always keep it in the same direction. do not take a reading from were the angle finder has been spun 180*, you will be reading the back side of the angle.
hard to tell from your photo, but i'd recommend a little inward angle as the side tubes go up. mine are pretty vertical and they could use a little more style. angling them inwards a little helps. othewise looks good.
I am not for sure where you are talking about putting an angle. I am debating on putting an inward bend just behind the a post (close to brian1's cage) to account for the narrowing of the tub, at the dash.
FWIW, I'd rather have a cage with welded corners and good triangulated gussets than a cage that is bent but without gussets. Think of it like domino's or a stud wall. With just a little effort it will tip right over, but with a bit of wind bracing its strong as hell and will hold up through about anything.
Got some 2" and 1.75" tubing locally and built the rest. I TIG welded mine. There is a lot of talk about DOM vs. HREW, but if you have a shaity welds who gives a rip what material you use. Take your time...do it right the first time. If you, a friend or family member gets hurt cuz you cut corners it'd be hard to live with yourself! Oh...tie it to the frame too, if it is tied to a rusty ass body, doesn't do much good. A lot of people skip this step :shaking:
