Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - FJ80-based 4-seater truggy build at Pacific Fabrication
View Single Post
Old 09-12-2011, 10:02 PM   #6 (permalink)
JESSE_at_TLT
Member # 30721
The first task once the build actually started was to cut the floorpan and firewall to the rough size and shape that we were planning on building around. Had to position the B-pillar crossmember in order to do that, as that was going to be the zero-point for the whole chassis (2x3" x 3/16" wall tubing). Notched the framerails to allow it to be mounted low enough that the floorpan can sit right on top of it. We also pre-notched that crossmember for the rocker-panel tubes before welding it into place. Then started hacking-up the rocker-panels and A-pillars.
gatosbros.com cruxstudio.com trailslesstraveled.com
JESSE_at_TLT is offline   Reply With Quote
