Originally Posted by toten
A friend of mine has an LS160P that he got a few years ago that isn't working in AC. Using 6013 or 7024 (what we had around) I can lay great beads in DCEP, but switch to AC and it just won't hold an arc. He had been hoping to do some aluminum TIG with it, but obviously without AC he can't do that - and he was having the same problem (can't hold an arc) when trying AC TIG.
Any suggestions for how to get it to work right? If not, what's the best contact?
Hi Toten,
There are several things you may be happening here. One, your settings, two the frequency gap on the machine may need to be adjusted. However, it seems that if you are able to DC TIG, then you have to fine tune your AC settings.
You can give our welder a call. Please send over an email to
help@longevitywelding.com with your contact info. Send this original message as well as our welders do not browse the forums. However, they will call you back once customer service issues a trouble ticket.
