Our Sales have been such a BIG HIT $225 BEADLOCKS We have extended our BIG SALE THRU THE END OF TIME on the 15 inch beadlocks.
16 thru 17 will be a extra $15.00 for the set.
And we have a TRUE ANTI CONE RING set $40.00 for a full set to do 4 wheels these are parts that fit between the outer and inner ring.
we are by far the leading beadlock cutting company in the industry and we are the only ones to have a patent pending anti cone ring (if you are shopping around and get a price for beadlocks and include anti cone rings send me a pm)
Our do it your self beadlock kits come with 4 outer rings and 4 inner rings
WE DO CUSTOM DESIGNS and any size 15 inch 16 inch 16.5 inch and even 17 inch. we now do 20 inch pm me for price. and shipping will only be charged actual charges no added charges........
CHECK OUT THE FOLLOWING PAGES FOR SOME PICS OF OUR WORK:smokin:
I have had a few questions asked mostly about bolts, powder coating and size so here goes
1...how thick are they and what are they made out of = they can be purchased in either 1/4 inch and 3/16 how can we do them out of 3/16 because we have a patent pending anti cone ring that when installed makes the whole setup 15/16 thick steel that is a engineered design and is the strongest in the industry for a Diy Beadlock
2... how many bolt holes = since we do custom work we can do as many as you like we try to stick with 28 for 15 inch and add 2 per wheel size.
3... can you make me a set of outers to replace mine = yes we just need some measurements and we can cut you some custom outers.
4... how tight do i need to torque the bolts? we have never had to go any tighter that 10 lbs. we like between 5 and 8 lbs.g But with the ANTI CONE RINGS you can go as tight as 20lbs
1...how thick are they and what are they made out of = they are 3/16 how can we do them out of 3/16 because we have a pattented anti cone ring that when installed makes the whole setup 7/8 thick steel that is a engineered design and is the strongest in the industry for a Diy Beadlock
3... what is a base color = pretty much any basic color like black, red, yellow, blue and silver we have many differnt colors but unless you are local i will stick with the basic colors i do have chrome it is a really polished silver that we will do.
4... can you make me a set of outers to replace mine = yes we just need some measurements and we can cut you some custom outers.
5... how tight do i need to torque the bolts? we have never had to go any tighter that 10 lbs. we like between 5 and 8 lbs.g But with the ANTI CONE RINGS you can go as tight as 20lbs
6... how much time does the powder coating take is it like 2 weeks = no we do it all in house so our turn around time from art to ship is no longer than 2 days.
I ordered last night and called to verify today. Only to find out that #6 is way out of th question. I need these by the 23rd of january is there any way. I have already paid on your site but I need to verify I want the punishers you posted on 1-5-12. The ones with four skulls and the eight sided star center. I need these in 17 coated red, order is in under lacie cowley. I hope you can make the ships in no longer than two days happen.
Those are going to sweet on my yota i am glad to have your first set of flames. Can't wait to get them and run them on the rubicon in a few weeks. Will post pics after tires are mounted.
here's one that is supposed to be a paint stencil so you can see the connection points, but the edges are a lot cleaner on the one above.
I would like the outer rings to be as small as possible cause I still want to be able to see my wheels (they're :grinpimp: and I don't want to hide them).
If the knuckles don't work out I'd like something really low profile like the basic AZ or Marsh.
No extra charge for the chrome(ish) finish? It's still powder coat? Have you had any in use to see how the coating holds up?
i can do them ill draw them up and as far as the chrome color it will hold up as well as any other if you lay it against a big rock it will sratch but as far as weather it will hold up like any other powder coatings pm sent
Here is the ANTICONE ring we have just for our kits they come as 4 parts to make 3 different thickness depending on your tires bead they run $10.00 each
and jhama78 just for you if you order a set of beadlocks from me ill do the ANTICONE ring for free for you
cut 4 sets before lunch thanks guys and gals i cut a water set for a young lady i will have pics up later today and i must say you people have some wild ideas again pics soon
These are for my buddy in Texas Woody hope you like them:flipoff2: these are cut from 2 pieces and welded together from the back dont ask how much they are you dont want to know:smokin:
