Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - TJ - Full width or stock width axles
View Single Post
Old 10-09-2012, 07:55 PM   #4 (permalink)
geberhard
Moderator
geberhard's Avatar
Member # 5861
I run front wider than rear (60 full and 14 bolt C+C), and worked really well, even better turning radius, etc. You can always add a spacer on the rear to balance things out as an option.
Back to the second poster really depends on the trails you do, some trails in CA are narrow and will not work for a full size or full width setup (i.e. Barret). Also full widths on the road are not too fun for the popo
geberhard is offline   Reply With Quote
