Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - TJ - Full width or stock width axles
View Single Post
Old 10-11-2012, 02:40 PM   #11 (permalink)
Turbos10
Member # 198319
A 35 spline semi float 60 will hold up fine. 5 or 6 lug will hold up fine; just upgrade to bigger studs if you are concerned.
And, seriously, just narrow it later?! If you are saying that you have obviously never narrowed a front axle, bought, and built supporting components to do so. I just did one and probably have 60 hours in the shop putting it all together. Take 10 hours out for machine work on 6 lug and brake conversion and you are still alot of time. Plus, you get to buy new axles or pay to have existing axles done. I dont guess this is as big an issue on stock axles, but with most everyone going chromo it is a big cost savings. You also get to buy all new brackets and refab all of your suspension brackets since once you start cutting everything changes.
CJ2 fiberglass and tube buggy, L67, RVB Art Carr 700R4, 3.8 Atlas, 60's, 40" Sticky Creepys.
Turbos10 is offline   Reply With Quote
