Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Inner race on spindle spins free?
View Single Post
Old 03-20-2017, 07:41 PM   #2 (permalink)
isbj60
Not Ashtray's dad
Member # 200478
Your outer bearing should be a slip fit. It has to move freely to properly set your bearing preload. If you are really concerned, use loctite 609 on the race, keep it clean when assembling, and set the preload quickly. That is a low strength retainer that can easilly be broken without heat but will keep bearings from spinning. Typically used on electric motor bearings.
isbj60 is offline   Reply With Quote
