Need a better bearing press
1K views 15 replies 10 participants last post by  Urban Wheeler
#1 ·
Pressing carrier bearings off with a socket, bearing puller, hi-lift and two c-clamps isn't that great, but it works.
#11 ·
desertsport said:
I like it now show me how to turn it into a press. seriously:confused:
Well if you remove the bearing puller and socket, then put the hilift on the bearing, that would work if you want to remove the ring gear, or two hilifs and two really big clamps. If it wasn't for the crosspin you could make something to go through the center of the diff to prees it on.
#14 · (Edited)
MT4Runner said:
You can make one of the "crappy" HF pipe benders work as a press with a few simple mods...
Why bother, their 12 Ton press costs $89 and works fine for carrier bearings ;)
Definitely an "A" for using what you have laying around. But you can attach a harmonic balancer puller to your clamshell and do it a little easier
