Copy and paste from this thread ->
http://forums.corral.net/forums/showthread.php?t=240902&highlight=junk
Some Junkyard Horsepower upgrades
Throttle Body
Ford Explorer 1996-98 5.0L 65mm req. linkage modification
Save your Fox TB to use the lever in which the cable attaches.
Heads
GT40's:
93 to 95 Lightnings
93-95 Cobra
Late 95- Early 97 Explorer (not milled as much as the Cobra GT40s)
1.84/1.54, 62-65cc, labled with GT in the corner and 3 bars on the end/front
mid 97-01 Explorers = GT40P 1.84/1.48, 60-62CC, angle plug, 4 bars on the front
351W D0OE or C9AE - 69-71 351w's 1.84/1.54, 60-62cc, large straight plug
289 heads - Small chambers
D8OE 351W - (Used on trucks and 87-84 Mustangs) 1.84/1.54, large chambers, good for sc/turbo
Intake Manifold
96-01 Explorer:
96-97 explorers - cobra style intake with internal egr & IAT provisions RF-F87E-9K461-BA
97/98-00 explorers - cobra style intake with cheaper casting & no EGR & no IAT RF-F87E-9K461-BB
5/16-18 x 6" bolts x 4
5/16-18 x 1" bolts x 2
3/8" npt tap for IAT
302 EFI Truck Lower - Holley type design, fits Saleen/Vortec and several box uppers
93-95 Cobra intake
93-95 Lightning
95 Cobra R
MAF Sensor
4.6 mass air meters (2v=70mm 4v=80mm)
Lincoln Mark 8, 80mm for 24lb
90mm Lightning MAF for 42# injectors
92-95 SuperCoupe, 70mm for 36's
Ford Mustang 1994-1995 V6 or 5.0L 70mm
Ford Crown Victoria 1992-1994 4.6L 70mm
Lincoln Towncar 1992-1994 4.6L 70mm
Mercury Grand Marquis 1992-1994 4.6L 70mm
94-97 Thunderbird 4.6 70mm housing is a direct bolt on to stock fox maf bracket. ( I suspect same housing as 93 cobra. )
Also, from what I understand the sensor part# of interest is F2VF-12B579-A1A or A2A.
Alternator
Good write up with pics on the swap here
These cars have 3G 130A clocked at 12:00 and will require fox bracket notched:
94-95 GT Mustang
94-06 V6 Mustang
94-97 3.8L Thunderbird **NON-S/C**
94-97 V6 t-bird
These cars have 3G 130A or 110A in a larger case clocked where connector will be jammed under the bracket. You can make these work, but they're not the ideal 3G for fox app upgrades:
93/94-99 3.0L Taurus (not 3.8L, check the 93, this may or may not have 3G)
95-98 3.0L Windstar
Small case 3G 95A with correct clocking and correct regulator. Some have incorrect 2 groove pulley, some have correct 6 groove:
92-94 3.0L Aerostar (early 92s were 2G not 3G, so check before you buy)
96-97 F series pickup with a 7.5L
Some of these use larger cased alternator, but can work, not all 3G's were 130a, see info
Other, not sure of their clocking or output:
94-04 3.8 (-98? small case, 95a?)
3.8L 94-97 T-bird/cougar
94-96 F-150 5.0L and 5.8L came with both 130A and 95A
3G's with WRONG casing:
3.8L Windstar does not seem to have the correct housing.
3.8L Taurus
Other Electrical
The bracket and megafuse holder off of a 97 Expedition can be used in conjunction with the 3G upgrade. The bracket houses 2 175amp megafuse in seperate carriers with individual covers. Also found them on a 97 F250. Cut em down, drill two 1/4" holes and they'll mount to the coil bracket.
High Torque Mini Starters
*check B4 u buy, some years may be standard "big" starters, since these came standard on the 92/93 5.0L I'd guess they were harder to find on other cars b4 those years and easier to find after*
(1992-96) Ford Bronco 4.9L, 5.0L, 5.8L w/ AT
(1992-02) Ford E Series 4.2L, 4.9L, 5.0L, 5.8L
(1992-98) Ford F Series 4.2L, 4.9L, 5.0L, 5.8L
(1990-91) Ford LTD Crown Victoria, Mercury Grand Marquis 5.0L
(1994-04) Ford Mustang 3.8L
(1992-95) Ford Mustang 5.0L
(1990) Ford Thunderbird 3.8L/Supercharged
(1991-97) Ford Thunderbird 3.8L, (1991-93) 5.0L
(1990-92) Lincoln Mark VII 5.0L
(1990) Lincoln Town Car 5.0L
***Retrofits***
(1982-91) Ford Mustangs 5.0L (302 CID) All
(1968-79) Ford Mustangs 5.0L (302 CID) w/ AT
(1969-73) Ford Mustangs 5.8L (351 CID) w/ AT
Injectors
Ford 19lb injectors (high impedance) #s: E5TE, D5B, F78E, F6VE
96+ Explorer 5.0 has better 19's than Mustangs
Ford 21lb injectors (high) #s: D9B, F65E (305/350 GM)
Ford 22lb injectors (high) #s: FOTE-D9B (vetts and range rovers)
Ford 23lb injectors (high) #s: F7TE, F8TE (7.5L truck)
Ford 24lb injectors (high) #s: F5DE, F1TZ, F2LE, F2LE-9F593-B2A, FMS-M-9593-A302
Ford 24lb injectors Ford 93-95 Mustang Cobra
Ford 24lb injectors 93-01 Lincoln Mark 8
Ford 24lb injectors other DOHC 4.6
Ford 24lb injectors 88-97 EFI 460's F250-450 & E250-450
Ford 24lb injectors Lincoln Aviator w/4v 4.6
Ford 24lb injectors Lincoln Navigator w/4v 5.4
26lb '00 LS1 F body, maybe '99 to?, same as Ford 24's
Ford 30lb injectors (high) #s: E9SE, F1SE, F1SE-E1A (3.8SC and SuperCoupes)
Ford 30lb injectors: 95/96 Ford 4.0L Explorer & Ranger & Other
Ford 30lb injectors: 89-91 SuperCoupe
Ford 36lb injectors: 92-95 SuperCoupe
Ford 39lb 03-04 Cobra
Ford 42lb 99+ Lightning
Taurus SVO some years had 24s some had 30s
I've noticed that several of the newer 4.6L cars have a newer design thinner injector that appears squared off instead of the round bodies we're all used to*. I pulled a set of 19s in this design and found that 1 of the injectors (cylinder #4 I think) that about a 30* bend on the head of the injector. Don't know if that will cause problems with our cars by spraying the fuel at an intake wall instead of down at the piston.
Be careful if you see injectors that you think may work. If they are "Low Impedance" you can cook your computer.
vers are ribbed
Electric Fans
94+ Mustang v6
94-96 Cougar
3.8L 88-95 Taurus or
3.8L 88-94 Lincoln Continental
Lincoln Mark 8
Ford Contour and FWD Mercury Cougar dual fans
Dodge Intrepid dual fans
Grand Marquis
Ford Windstar/Mercury Villager
98-00? Mercury Mistique
Nissan Quest minivan and Mercury Villager fan is said to be a perfect fit
"seem to fit based on your level of tolerance to fabricate brackets and such from what I've read. Personally, I have a 2 spd from a 94 Villager." 1BAD6T6
Link to good writeup on changing to Mark 8 Fan
Radiator
Late 5.0 Cougars have nice alum. radiators (these fit the Mark 8 electric fans really good)
Oil Pan
Oil pan from late 90s crown vic's with 351 is a double hump design and can be used if you plan on doing a 351 conversion in your fox.
Other
Don't forget to pick up some extra relays. These cost over $10 at most auto parts stores and are pocket items at the JY. I always keep a spare in my car incase my fuel pump relay goes.
