DANA 44/60 HIBRID hard part is done
ok, here is the deal, I got this ones for my CJ, but I decided to go full width.
I've a pair of matching DANA 60/44 hybrids FOR A NARROW TRACK CJ Front Dana 60 center section Dana 44 tubes and hubs, 6 lugs, chevy style setup spring pads at 30" Passenger side gears are 3.54 need long shaft to be cut down (I've it) It has a some sort of locking unit the width from rotor base to rotor base es 54" $600.00 http://i759.photobucket.com/albums/x...s/P1030903.jpg http://i759.photobucket.com/albums/x...s/P1030904.jpg http://i759.photobucket.com/albums/x...s/P1030905.jpg Rear Dana 60 center section Dana 44 tubes and hubs, 6 lugs, chevy style setup spring pads at 30" center pumpkin gears are 3.54 need both shafts disk brakes FULL FLOATER SETUP THE HARD PART IS DONE!!! the width from rotor base to rotor base es 54" $500.00 THE PAIR FOR $1000.00 http://i759.photobucket.com/albums/x...s/P1030902.jpg http://i759.photobucket.com/albums/x...s/P1030901.jpg http://i759.photobucket.com/albums/x...s/P1030901.jpg http://i759.photobucket.com/albums/x...s/P1030907.jpg http://i759.photobucket.com/albums/x...s/P1030908.jpg Located in Anderson,CA
POR MIS PISTOLAS!!! Last edited by xtremos; 04-08-2012 at 08:29 PM. |
Newbie
Member # 151896
Please e-mail contact info to Tolson@shimmick.com. I need the front end for my 76' CJ 7 with the same 54" width measurements. Let's make a deal.
#8 (permalink) | |
POR MIS PISTOLAS!!! |
#18 (permalink) |
Member # 126796
By rotor base to rotor base are you meaning WMS or are you measuring the inside dimensions. I just want to make sure we are both speaking the same measurements.
I have a 86 CJ7 that I need to do something other than the Scout 44 that I have as I am about to put RCV's into it and the D44 ring gear will be my worry. Let me know pls.
At some point while using Jeep speak you will here a loud @#$PLOP$#@. That was your head being pulled out of your ass. Now clean the shit out of yours ears and listen. |
#20 (permalink) | |
