Brand new Dynatrac ProRock Axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 11-22-2011, 08:35 AM   #1 (permalink)
Member # 183665
Dynatrac Prorock 60s
Front
Complete Custom Dynatrac Pro Series 60 High-Pinion Front Axle Assembly
Custom Machined Dynatrac Pro Rock 60 High Ground Clearance, High Pinion (Reverse-cut) Heavy Duty Nodular Iron Housing
Axle Width 69.75
ARB Air Locker Differential, D60, 35 Spline w/ARB Kit
D60 Ring and Pinion, 5.13 Reverse-cut
Input Yoke, 1350 U-Bolt Style w/Yoke Kit
35 Spline, 1.5" Diameter Heavy Duty Alloy Front Inner and Outer Axle Shaft Assemblies, Spicer 1480 Axle Joints w/Warn Premium 35 Spline Locking Hub
Dynatrac Heavy Duty Dynaloc Manual Locking Hubs
Dynatrac Pro 60 Heavy Duty Wheel End Package (Includes HD Ball Joint End Forgings, Knuckles, Spindles, Wheel Hubs, and Bearings)
Wheel Bolt Pattern - 8x6.5"
Dynatrac Stub Hub Conversion Kit - Upgrade
Heavy Duty F-350 Dual Piston Disc Brake Assemblies
Clean Tubes (No Suspension Brackets)
Dynatrac Custom Suspension Bridge
Dynatrac Pro Rock 60 Nodular Iron Diff Cover
Dynatrac Steering Arm, Long, Blank
Rear
Complete Custom Dynatrac Pro Series 60 High-Pinion Full-Float 8x6.5"
Custom Machined Dynatrac Pro Rock 60 High Ground Clearance, High Pinion (Reverse-cut) Heavy Duty Nodular Iron Housing w/Pro 60 Nod Iron Diff Cover
Matched Housing Geometry and Pinion Angle for Vehicle's Suspension
Dynatrac Dual Sump/High Volume (DSHV) High Pinion Angle Oil Modification
Axle Width - 69.75"
Detroit SoftLocker Differential, D60, 35 Spline
35 Spline, 1.5" Diameter Heavy Duty Alloy Rear Full-Float Axle Shaft Assemblies
E-350 Vented Rotor Heavy Duty Disc Brake Assemblies w/Parking Brake, 16" Wheel Min.
Dynatrac Heavy Duty 8x6.5" Full Float Package (Includes HD Full Float 35 Spline Axle Shafts, Heat Treated Spindles, Bearings & Stubby Wheel Hubs)
Asking $14500 OBO
Direction has changed, but i cant loose too much money on these. I could work up a deal, but its it too low i wont sell and ill just run these.
They are still in the crate, and ready to go. Located in AZ
Clicky for full size.
paintsnow is offline   Reply With Quote Quick reply to this message
Old 11-23-2011, 05:57 AM   #2 (permalink)
TBD
westracing01's Avatar
Member # 194369
What the hell? What direction could your rig have possibly changed to from this?
Giving money and power to Congress is like giving whiskey and car keys to teenage boys. ~ PJ O'Rourke
westracing01 is offline   Reply With Quote Quick reply to this message
Old 11-26-2011, 11:12 AM   #3 (permalink)
Member # 183665
No longer for sale.
Thank you.
