Ford HP D44- Geared and Locked - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 07-23-2012, 03:57 PM   #1 (permalink)
Member # 123706
Ford HP D44 & 14 Bolt- Geared and Locked
***Updated***
1978 Ford F250 Dana 44- full width 69" WMS
I built it about 6 years ago, but it only has about 6000 miles on it. It's been sitting in my garage for almost a year now.
High Steer Arms- GM 1 ton TRE's and DOM tie rod
The right side TRE is bent from hitting a rock, but it could be straightened out in a press, I just haven't had time.
Detroit Locker
Yukon 4.88's with full install kit
New Dual Piston Calipers, pads, and rotors
All new wheel bearings and seals
New Ball Joints
Mile Marker Supreme lockout hubs (with a spare set of Warns)
1 Spare outter shaft, 1 spare long inner and short inner shafts
It was set up for 3-link, but now has the brackets removed and the spring pad tack welded back on. I can finish welding it if you'd like.
I've got about $2000 in it including labor.
Axle comes with Early '80's Chevy 14 bolt. 4.88 gears, detroit locker. Factory drums
Here's the story on the 14 bolt. When I upgraded to a 60 front, I changed to 5.13's. These gears were run in my other 14 bolt, and have the same mileage on them as the front. They are set up and ready to run, but I have not run them in this axle. New pinion bearings and seal was used for setup.
The Detroit is a factory locker from a GM Eaton rear end. It is 17 spline, but don't let that scare you. If you are unfamiliar with the Eaton, read up on it here.
http://www.pirate4x4.com/forum/chevy...aton-h072.html
I'll also throw in 3 pairs of leaf springs.
1st pair- Junkyard 63" Chevy's from a 4x4 (4 leaf + overload)
2nd pair- Unknown spring over springs for a CJ/YJ. Look like 2.5" springs
3rd pair- National Spring CJ/YJ rear leafs with 6.5" of lift
Both the pairs of CJ/YJ leafs came from Morris Hansen's YJ- link below
Coiled -- 4WD & Sport Utility Magazine
$1700 for everything
Trade for a 1960-1966 Suburban, or 1960-1972 Chevy/GMC short box 2wd
Located at zip 68516
I'll ship on your dime, but you have to have everything set up (pallet, etc) and I will drop it off somewhere here in Lincoln or Omaha, NE
We could also set up meeting somewhere
PM me with offers- Not willing to part it out yet
2011 Cummins G56 / 1997 TJ- One Tons & Coilovers / 1972 K5
BoDuke25 is offline   Reply With Quote Quick reply to this message
Old 07-26-2012, 07:54 PM   #2 (permalink)
Member # 123706
Ttt
Old 07-29-2012, 07:34 AM   #3 (permalink)
Member # 123706
Back up top
Old 07-29-2012, 10:30 AM   #4 (permalink)
Member # 112050
If you do decided to part it out in the future, PM me, I'd like a few things off it..
Ryan Piggott -RuffStuff Specialties -1969 f250 4x4 Cummins @rpiggott871
1969f100 is offline   Reply With Quote Quick reply to this message
Old 08-06-2012, 03:59 PM   #5 (permalink)
Member # 123706
Bump
Just for comparison, here's new price on some of these parts if you're thinking of building your own
Detroit- $600
Yukon 4.88's- $225
Yukon 14 bolt 4.88's- $330
Total- $1155
And that's not including the axle, gear set up, new ball joints and brakes and the extra shafts and lock outs, high steer arms and DOM/1 TRE tie rod and brackets.
Old 08-20-2012, 09:05 PM   #6 (permalink)
Member # 123706
Headed from Lincoln, NE to Montrose, CO in September, I could deliver along the way
Old 11-17-2012, 10:17 AM   #7 (permalink)
Member # 123706
Back up
Original ad has been updated. I added the rear axle and leaf springs.
Old 11-21-2012, 09:05 PM   #8 (permalink)
Member # 123706
Bump
I've also got a '79 Ford NP205 and a CV front drive shaft from a 1993 Cummins I'll throw in.
