I have a RE drive shaft with the tap/cut SYE. - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 03-24-2003, 11:44 AM   #1 (permalink)
TOYJ-7's Avatar
Member # 14741
tail shaft taped for RE SYE
$60 cut tail shaft taped
TOYJ-7 is offline   Reply With Quote
Old 03-24-2003, 08:35 PM   #2 (permalink)
Member # 10869
Send a message via AIM to 90wrangler
where in ca are you located?
jeeps, a never ending project
90yj with full width axles, rear 14bolt 5:13's , HP44 front 5:13's with high steer and an ARB, all on 44044's.
LS1 motor w/ sanderson headers LS6 intake...3.8 ATLAS 32 spline F&R...4L60E tranny
90wrangler is offline   Reply With Quote
Old 03-25-2003, 06:55 AM   #3 (permalink)
Member # 7247
Send a message via AIM to GO 4LO
Could you measure the overall length of the shaft for me from the center of the plate-style tcase flange to the axle-end ujoint? Thanks!
Chris
99 TJ on 40's - trailrig
01.5 Dodge 2500 qc sb 4x4 Cummins - towing/dd
96 Dodge 2500 xc lb 4x4 Cummins - sledpulling
93 Dodge W250 rc lb 4x4 Cummins - racing
97 LT1 Firebird - dd
GO 4LO is offline   Reply With Quote
Old 03-25-2003, 07:39 AM   #4 (permalink)
TOYJ-7's Avatar
Member # 14741
I am in Fremont and it is off a RE 4.5" lift
Old 03-25-2003, 07:59 AM   #5 (permalink)
Member # 7247
I'm trying to see if it will fit my 4-banger 5-speed w/ ~5" susp. lift and a low-pinion Ford 9 rear.
Chris
Old 03-25-2003, 10:41 AM   #6 (permalink)
TOYJ-7's Avatar
Member # 14741
Chris
Whats your Stock lenght of your driveshaft from ujoint to u joint? Mine was 13"s(stock shaft)
Old 03-26-2003, 08:50 AM   #7 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 03-27-2003, 08:57 AM   #8 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 03-27-2003, 10:23 AM   #9 (permalink)
Member # 7247
I don't think it will fit mine then. Thanks anyway, and btt for ya.
Chris
Old 03-30-2003, 10:03 AM   #10 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-04-2003, 03:45 PM   #11 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-05-2003, 11:14 AM   #12 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-07-2003, 07:33 PM   #13 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-11-2003, 03:26 PM   #14 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-11-2003, 04:51 PM   #15 (permalink)
NothernAZxj's Avatar
Member # 8528
So this is a used setup.........I will be using it for a comanche...the DS is useless....I will give ou 100.00 shipped for the SYE
Brian Harmon
NothernAZxj is offline   Reply With Quote
Old 04-12-2003, 11:08 PM   #16 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-15-2003, 12:10 AM   #17 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-20-2003, 01:45 PM   #18 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 04-21-2003, 07:40 AM   #19 (permalink)
Member # 12123
Its a long shot, but is the sye still in the tcase. If so, I am interested in the whole tcase with sye and drive shaft as long as tcase work fine. I am pretty sure it will slap on my 98 tj with a 4.0L auto. Thanks.
rocksalt is offline   Reply With Quote
Old 04-21-2003, 11:28 AM   #20 (permalink)
TOYJ-7's Avatar
Member # 14741
Nope I am running the T-case until I break it, or until I have the money for a atlas.
Old 04-21-2003, 04:25 PM   #21 (permalink)
PIA
PIA's Avatar
Member # 1739
Extended/compressed measurements please. oics would be nice too
thanks
If the path does not have any obstacles, it probably won’t lead you anywhere
PIA is offline   Reply With Quote
Old 04-21-2003, 08:11 PM   #22 (permalink)
Mrburns's Avatar
Member # 18210
Send a message via AIM to Mrburns
$50 for the SYE kit...?
Mrburns is offline   Reply With Quote
Old 04-26-2003, 03:51 PM   #23 (permalink)
TOYJ-7's Avatar
Member # 14741
Old 05-15-2003, 11:20 PM   #24 (permalink)
TOYJ-7's Avatar
Member # 14741
