HP Dana 60 TJ Currie Triangulated 4-link in WA - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 12-13-2004, 08:53 PM   #1 (permalink)
theckel's Avatar
Member # 39975
HP Dana 60 TJ Currie Triangulated 4-link Rear in WA - more info + pics!
Hi-pinion Dana 60 housing from a mid-eighties Ford F350. Converted in July of 2003 by Currie Enterprises for use with their triangulated four-link TJ rear suspension. Retubed with new 3-1/4" .250 wall tubes. Housing is 70" wide and the ends are unfinished but can easily be cut to any desired width and fitted with the ends and shafts of your choice, to mount drum or disc brakes and any common bolt pattern (housing ends and shafts are available from many sources including Moser Engineering).
Asking $800 firm - this setup from Currie runs $1,299 (including ends, cover and yoke), plus at least another $450 for the TJ brackets - here's your chance to save! Center section was hot tanked and "steelabrated" but has minor surface rust from sitting for a year. Includes bearing caps, but will need everything else including bearings and races plus a differential, shims, seals, ring & pinion, yoke, cover and axle shafts.
Housing ends can be installed by any competent race shop equipped with the proper alignment tools to do "narrowed" rear ends (e.g. for drag racing); Moser will perform this work for $85 (plus the cost of the housing ends, approx. $70).
I have the original invoice from Currie. Please note that this axle requires a "triangulated" rear suspension system like the one from Currie. To install this axle in your TJ, you will need to make your own or to purchase braces, upper and lower control arms, and a modified exhaust.
Buyer pays actual UPS Ground shipping cost based on 120 lbs OS3 from ZIP code 98272 (approx. $130 to the east coast). Located in Monroe, Washington. Pictures available upon request via email.
theckel is offline   Reply With Quote Quick reply to this message
Old 12-14-2004, 07:24 PM   #2 (permalink)
theckel's Avatar
Member # 39975
btt
Old 12-15-2004, 07:35 PM   #3 (permalink)
theckel's Avatar
Member # 39975
btt
Old 12-17-2004, 09:36 AM   #4 (permalink)
Member # 24149
any pic's? any trades? i have a small 4x4 shop in vancouver.
reodesign@aol.com.
360-909-8544
randy
PIG PIN is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 11:41 AM   #5 (permalink)
theckel's Avatar
Member # 39975
I'd consider a trade plus cash for one or more of the following items:
35-spline Dana 60 Detroit Locker (or possibly ARB)
Dana 44 Detroit Locker (ditto)
4.56-4.88 Dana 60 R&P (new or used in good cond)
4.56-4.88 Dana 44 RR R&P (ditto)
Cadillac calipers (76-78 w/ebrake)
Hummer 12-bolt rims w/runflats
Atlas II (any ratio) or Rubicon xcase (NV241OR)
I'll send some pics tonight when I get home from work.
Old 12-17-2004, 04:02 PM   #6 (permalink)
Member # 9895
Pic's please, from different angles.
Salvage_TJ is offline   Reply With Quote Quick reply to this message
Old 12-17-2004, 11:14 PM   #7 (permalink)
theckel's Avatar
Member # 39975
Pics sent (ignore the last one of the front D44).
Old 12-20-2004, 12:53 AM   #8 (permalink)
theckel's Avatar
Member # 39975
More information: When I ordered this from Currie I changed my order at the last minute to standard TJ brackets (which is what my paperwork says), but they screwed up and put the 4-link brackets on instead. They've told me I can get the brackets on this housing changed to standard TJ 5-link for the cost of shipping it back to Currie (~$100). I can then have it shipped to whoever buys it (buyer pays the shipping to/from Currie).
Here are some pics:
Old 12-28-2004, 03:54 AM   #9 (permalink)
theckel's Avatar
Member # 39975
ttt
Old 01-03-2005, 12:52 AM   #10 (permalink)
theckel's Avatar
Member # 39975
ttt
Old 01-16-2005, 07:35 PM   #11 (permalink)
theckel's Avatar
Member # 39975
btt
Old 01-17-2005, 11:34 PM   #12 (permalink)
Csnyder's Avatar
Member # 12918
Please PM me your number, I am very interested and also happen to be in Monroe.
Thanks,
- Chris
Trailed, not trailered.
Csnyder is offline   Reply With Quote Quick reply to this message
