WFO Concepts
Member # 299
44 front, ARB, 9" rear, 61.5" wide $2000 Auburn
I am selling the axles out my beater 68 CJ-5. The frame just won't hold up anymore. The front is a Waggy 44 that has been cut down. It is setup for spring over, has 4.10 gears and an ARB. The spring width is 27", and the overall width is 61.5" It has Ford 1/2 ton outers with disc brakes and internal hubs with 5 on 5.5 lug pattern. It has crossover steering, but not high steer. The Tierod is 1.25" with 3/4 heim joints, and the draglink is 1.25" with Chevy draglink ends. the stainles brake lines and u-bolts and plates are also included. Lastly, there is one complete set of spare front shafts, and another short side inner shaft.
The rear is a factory 61.5" wide Ford 9 3/8. It is a little bigger than a 9". the housing is the large bearing, big banjo. It is 31 spline with factory posi. The posi hooks up really well! It has a torque arm bracket on it, and spring perches for the narrow frame CJ. The brake lines, u-bolts, and spring plates are also included. It has drum brakes. I would like $2000 for the set. They have both been beat on pretty well, but I never broke anything with my Buick V-6 and 35" tires! I will not ship the axles. You must pick them up in Auburn, ca. call 530-268-9494, or my cell 530-308-2485 |
