Rear Rockcrusher HP 60 Jeep width - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 01-13-2009, 09:09 PM   #1 (permalink)
Member # 25392
Rear High Pinion Rockcrusher 60 for sale. This is a bada$$ axle . The pinion is high enough were most could run a non-CV driveshaft.
High Pinion 60
Semi-float
35 spline superior axles and gears
4:88 gears
Detroit Locker
1350 Yoke
1/2" thick tubes
smooth bottom
Ford 9 inch outers (large style)
Large 11" drum brakes (much larger than the factory Jeep brakes)
always ran Mobil 1 sythetic.
5 x 4.5 bolt pattern, shafts also drilled for 5 x 5.5 bolt pattern.
Jeep TJ width approximately 61.5" WMS to WMS. Pinion offset approx. 1.5" per factory Jeep specs.
Gears setup and axle built by Mad4wd
I purchased this axle new for my Jeep TJ from MAD4WD a few years ago. It was setup for a three link wishbone suspension, but can eaisly be setup for anytype of suspension. It includes coil spring pads, lower control arm tabs and shock tabs. It has a mounting platform machined housing for upper links. This axle was never pushed hard as I ran 36" TSL on it. It has very few trailrides on it < 12, not sure on the miles the Jeep was not a daily driver. I hate to sell this axle but, I am rebuilding the Jeep and going full widths. I am located near Chattanooga TN and would prefer not to ship, could meet within resonalbe distance. Asking $2500.00, this axle would cost far more to build.
Here a few pictures of the axle when it was brand new and I will post some current pictures in a few days. The axle is out of the Jeep and ready to go.
Some pictures Mad4wd sent me when it was being built.
Root TIG welded
2003 Rubicon 104" wheelbase
tnjeep is offline   Reply With Quote Quick reply to this message
Old 01-14-2009, 02:31 PM   #2 (permalink)
Member # 117710
what are doing with the front axle?
wojo95 is offline   Reply With Quote Quick reply to this message
Old 01-15-2009, 03:26 PM   #3 (permalink)
Member # 25392
I am going to hold onto the front axle until I can sell the rear. Its a lp Stock TJ dana 30 with 4.88 gears.
Old 01-18-2009, 11:44 AM   #4 (permalink)
Member # 25392
ttt
2400.00 obo
Old 01-26-2009, 12:10 AM   #5 (permalink)
Member # 128177
Send a message via MSN to acp51
rear axle
Hello,
Do you still have?
acp51 is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 04:31 PM   #6 (permalink)
Member # 25392
TTT still have it
Old 02-13-2009, 09:30 PM   #7 (permalink)
Member # 25392
ttt
Old 02-14-2009, 10:50 AM   #8 (permalink)
Member # 25392
I drained the fluid and took pictures of the gears and axle as it sits now.
Old 02-14-2009, 12:53 PM   #9 (permalink)
Member # 128540
Sent you a PM
GCALLY is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 01:03 PM   #10 (permalink)
Member # 25392
PM replied
Old 02-14-2009, 11:30 PM   #11 (permalink)
Member # 128177
sdent you a pm, interested.
Old 02-14-2009, 11:36 PM   #12 (permalink)
Member # 128177
interested in rear axle
Hi, interested in rear axle. As far as reasonable distance, what did you have in mind? I am in Chicago. What forms of payment do you accept? Paypal?
thanks,
Anthony
Old 02-15-2009, 12:30 PM   #13 (permalink)
Member # 25392
sale pending
