Dodge Dana 60 front & Dana 70 rear axles - So Cal - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 10-22-2010, 10:13 AM   #1 (permalink)
TruckTrader's Avatar
Member # 12647
Send a message via MSN to TruckTrader
Will sell both together for $900. or trade for a rebuild on my Dodge transmission.
Both axles are out of a 95 Dodge Ram 2500 V10 SRW pickup with 181k miles. Come and drive them before I pull them if you want. The axles are stock and look like they have never been used off road at all. They do not have the manual hubs on them, stock setup from Dodge.
Dana 60 front axle 4.10 ratio $800 complete hub to hub
Dana 70 rear axle 4.10 ratio $200 complete drum to drum
No cash? No problem, charge some parts I need for a build on your credit card! Axles are still on the truck in Covina, CA
Suzuki Samurai Twin Sticks
Formula Toyota #034
TruckTrader is offline   Reply With Quote Quick reply to this message
Old 10-23-2010, 03:27 PM   #2 (permalink)
Member # 12647
ttt
Formula Toyota #034
Old 10-23-2010, 03:39 PM   #3 (permalink)
Member # 147836
does the 60 have manual hubs are unit bearings
blown xj is offline   Reply With Quote Quick reply to this message
Old 10-23-2010, 03:45 PM   #4 (permalink)
Member # 12647
It does not have the manual hubs on it.
Formula Toyota #034
Old 10-24-2010, 06:56 PM   #5 (permalink)
Member # 12647
ttt
Formula Toyota #034
Old 10-26-2010, 01:49 PM   #6 (permalink)
Member # 12647
Gonna pull them soon, make offer.
Formula Toyota #034
Old 10-27-2010, 01:38 PM   #7 (permalink)
Member # 12647
damn, thought somebody would want these for a project
Formula Toyota #034
Old 10-27-2010, 02:48 PM   #8 (permalink)
Member # 44376
Send a message via AIM to TurboJeep275
Front is driver drop? ball joint? Unit Bearing? If so then thatís probably why thereís not much interest.
1980 CJ-5, 258 on the pane, 100" WB, 39.5 Iroks, 60/14 yada yada yada
2006 Dodge Ram, 4x4, Cummins, AFE intake, Muffler Delete, Jake Brake
TurboJeep275 is offline   Reply With Quote Quick reply to this message
Old 10-27-2010, 02:50 PM   #9 (permalink)
Member # 12647
Originally Posted by TurboJeep275 View Post
Front is driver drop? ball joint? Unit Bearing? If so then that’s probably why there’s not much interest.
I think all Dodges are passenger side drop and King Pin but I'm not sure, I will check. It's the unit bearing setup which is not a plus for us wheelers.
Formula Toyota #034
Old 10-27-2010, 03:21 PM   #10 (permalink)
Member # 44376
Newer ones are drivers drop and ball joints not exactly sure when they switched over though.
If it was passenger drop w/ king pins and regular hubs Iíd be all over it.
Old 10-27-2010, 07:56 PM   #11 (permalink)
Member # 147836
x2
Old 10-27-2010, 08:56 PM   #12 (permalink)
Member # 108644
off of a second gen v10 dodge it would be a ball joint, unit bearing, drivers side drop axle with a CAD unit, not the best i admit... I wheel the same axle on a full size 1500 dodge no issues with 39.5 TSL's with a detroit locker with 5.38 gears... I wish you were around pa. Id pick that rear up in a heartbeat.
Is it a limited slip rear?
Lanky is offline   Reply With Quote Quick reply to this message
Old 10-27-2010, 09:04 PM   #13 (permalink)
Member # 12647
Oh, so that's why nobody wants it! I am in FL right now but will check when I get back to see if it's LS or not. Thanks for the info.
Formula Toyota #034
