Cut and turned FJ40 axle housing for Spring Over conversion - $200
Located in Loveland, CO
For Sale I have a front Toyota FJ-40 Land Cruiser axle housing that has been cut and turned for a spring over axle swap with leaf spring perches welded on. This is just the housing, no 3rd, no steering parts, no shafts, but you should already have all that if you have a running 40. This housing will pay for itself in the cutting, grinding, and welding time that is involved in doing a cut and turn for the correct SOA conversion on your FJ-40. Please e-mail number and I will get back soon. I am not sure of the exact amount of degrees this was turned since I got it like this, but it was on a running, well built cruiser with leaf springs on top of the axle. Steering balls look straight, and inner axles just pulled right out. No gussets or any other unnecessary welding has been performed on this housing.
Thanks!
