Member # 8553
6 lug narrowed d60's / 40 LTB's R15 Central Iowa
*** Everything But the Wheels are sold and gone Thx guys ***
Axles would best fit a Toyota mini truck but you could use them however you want. 40x16 R15 LTB's with good tread no plugs etc. Outer lugs on the front two are a bit rounded from wheeling but tread depth is near new only trail wear. ![]() $800 ![]() ![]() I have Stazworks 15x10 6 lug 3.5" BS beadlocks that the tires are mounted on but perfer not to sell, make an offer on the package if you want. ![]() Front Chevy LP Dana 60 housing narrowed to ~63.5 width originaly setup for Toyota to be center on mini truck sping perch width. C's rotated for 10 degree pinion angle with good caster. Currently setup for 3 link with coilovers Includes: OX locker with Air actuator (works sweet) 5.38 gears 6 lug hubs and 1/2 ton brakes Parts Mike High steer arms & ARP studs, passenger side is a double arm Behind the axle steering with PSC ram (leaking Body O-ring) Custom long side Superior 4340 Domestic Shaft 35 Spline stock shortened shaft (welded in Joint good for spare) Stock inner for short side 1350 Yoke $2500 If wanting to run on leaf springs I will include all required harware, steering will need to change to standard highsteer vs behind the axle though, I will include the correct 2 Parts Mike arms for this. Prefer to sell partialy complete, but could upgrade as needed. (Summit Machine drive flanges, full chromo superior shafts, long 300m joints, spicer 35 spline outers, etc) Rear Axle Ford LP housing Semi Float ~62.5 WMS 35 Spline Dutchman Axles with set 20 bearings Detroit Locker 5.38 Gears Disk Brakes Rockcrusher cover 1350 Yoke Setup for double triangulated links with coilovers $1000 Also have leaf spring u-bolts and plates for rear comes with track bar. $50 D60 pinion to Toyota drive shaft, have one add $75 to either axle All good stuff, I am just going to go full width and 8 lug so I have a pile of parts I am not using!
Ummmm Beer Last edited by Satan's_Minion; 03-05-2011 at 08:42 AM. |
Member # 8553
Would consider partial trades on Ford HP housing and or 20" beadlocks (8 lug)
![]() ![]() Can prodvide more pictures as needed. Located in Des Moines Iowa, can ship anything seen here on pallets at buyers expense. Could Meet within a few hours as well.
Ummmm Beer |
Member # 8573
could you send me more pics of the front axle to broken_wrench@yahoo.com
Member # 100556
Pics on front axle @ zopiloto@live.com please , thanks. What do you think shipping would be to 92563???
#13 (permalink) |
Member # 33510
Interested in the tires if they dont sell.
Northridge Fabrications Montrose, CO 970.626.6090 XJ, TBI SBC/TH350, Atlas2, 4-linked F/R, 60s, 42s |
