1977 Chevy 1/2 Ton 4x4 Axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Axles/Tires/Wheels For Sale
Old 04-13-2011, 09:46 AM   #1 (permalink)
Member # 165171
OK, I've been hit up a couple of times about parting these axles out, so If I take the time to disassemble them I will take the following on parts:
Detroit Locker for Chevrolet 12 Bolt Rear Axle - $300.00
4:88 gears for Chevrolet 12 Bolt Rear Axle (1 chipped ring tooth, good pinion gear & shaft) - $75.00
1977 Chevrolet 12 Bolt Rear Axle Shafts (6 Lug) - $100.00 for pair
1977 Chevrolet 12 Bolt Rear Axle Housing - $50.00
Open Carrier with 4:88 gears for Chevrolet Dana 44 Front Axle (with pinion shaft & gear) - $200.00
Pair of Flat top knuckle for Chevrolet Dana 44 Front Axle (Stock) - $100.00
Passenger Side Axle Shaft for Chevrolet Dana 44 Front Axle (Stock) - $50.00
1977 Chevy Dana 44 small bearing spindles - $25.00
1977 Chevy 1/2 Ton Dana 44 6-lug hub assemblies with stock wheel studs - $50.00
1977 Chevy 1/2 Ton Dana 44 Stock backing plates/caliper mounts - $25.00
1977 Chevrolet Dana 44 Front Axle bare housing (or just the C's) - $50.00
Will ship parts with buyer paying shipping cost
offroad4play is offline   Reply With Quote Quick reply to this message
Old 04-15-2011, 09:28 PM   #2 (permalink)
Member # 165171
bump
Old 04-19-2011, 10:13 PM   #3 (permalink)
Member # 112985
WOuld you part out the locker?
Your truck is just an image of you, so mine is bad and nasty!!!
orbot is offline   Reply With Quote Quick reply to this message
Old 04-20-2011, 09:36 AM   #4 (permalink)
Member # 165171
Old 04-20-2011, 10:09 AM   #5 (permalink)
El Jefe's Avatar
Member # 14072
Location?
Are the front and rear currently complete and assembled? I might be interested if they're still together depending on location.
Thus far you have been adrift in the sheltered harbor of my patience.
El Jefe is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 08:18 PM   #6 (permalink)
Member # 188950
Small bearing spindles
I am interested in the spindles for $25, are they indeed the small bearing?
Kmills is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 08:21 PM   #7 (permalink)
Member # 188950
Also how can I contact you and maybe get a pic
Old 04-25-2011, 07:28 AM   #8 (permalink)
Member # 165171
PM sent
Old 04-28-2011, 04:17 AM   #9 (permalink)
85K5DSL's Avatar
Member # 83330
pm sent
85K5DSL is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 12:10 PM   #10 (permalink)
Member # 112985
So wheres the pics?????
Old 04-29-2011, 07:41 AM   #11 (permalink)
Member # 165171
Working on getting pics of parts.... Have not been off work enough to disassemble & take pics.. will try again this weekend
Old 05-10-2011, 07:44 PM   #12 (permalink)
Member # 112985
Well?
