3"x.250" wall tubes, measures around 70" end of tube to end of tube. Comes with fill plug, and all the 3rd member studs, and a drain plug as well. There are no ends included or installed, this is the blank housing/hardware only. I need to get $400 cash for it. In VEntura, CA, 93001. I will also throw in some new model big bearing axle retainers for semi-float set up.
Chris Alston's Chassisworks, Inc.; Chris Alston's Chassisworks, Inc. - FAB9 M/S, NO BRACKETS, 3" TUBES
mounting flange is machined flat after it is welded, measures at around 0.355" thickness with my calipers, and has some thicker internal ribs.
