Same as these:
http://www.ballisticfabrication.com/D60-high-steer-kit-for-kingpin-axles_p_1246.html
Includes all hardware, plastic washer thing, set screw.
Holes in arms drilled for 3/4" thru holes for tie rod, and drilled trough and sleeved for a 5/8" bolt for the drag link. A little out of round due to bolts coming loose. Could weld fill and drill new holes...
4 ea studs and nuts, full length, full size nut
4 ea studs and nuts trimmed (see pic below)
I ground the inside edge of mine to clear my shocks. I also cut off the inside studs to clear the shocks.
There is almost no strength difference, and the taper in the holes is not modified.
4ea of the 8 studs have been cut off, (the nuts as well) similar to the below -
Grinding on inner edge -
$215 shipped anywhere USPS flat rate boxes go.
