Dana 60 Ford Front Disc Brake Conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 08-24-2011, 08:39 AM   #1 (permalink)
Member # 148051
Our Ford Dana 60 Front 3/4 ton disc brake conversion brackets were developed due to customer demand. Note: uses 3/4 ton CHEVY rotors and calipers.
Brackets come with stainless steel spacers.
Please call to order.
For Jeep JK Dana 60 swap info give us a call. The swap brackets for ABS equipped vehicles include a feature for holding the wheel speed sensor and use the stock 1 ton ford rotors.
Virginia 4x4 is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 10:17 AM   #2 (permalink)
Member # 36943
Send a message via AIM to Skerb
will this allow you to run 15" wheels
Skerb is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 10:30 AM   #3 (permalink)
Member # 148051
it depends on the wheels but to the best of my knowledge you will still have to grind on the calipers just like you must do with our rear disc brake conversions to be able to run most 15" wheels.
Old 10-14-2011, 05:17 AM   #4 (permalink)
KyleQ's Avatar
Member # 83837
It should - I'm running 15's with the factory 1 ton dual piston calipers Yeah - it works, but I ground so much material off the calipers and their mounting surface I'm having brake issues. I will be purchasing this product to resolve the issue - if those big twin piston calipers can be ground to fit, the 3/4 ton stuff should be a lot easier, especially with the slide pin design.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60, Powr-Lok 70U - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 10-14-2011, 07:24 AM   #5 (permalink)
Member # 148051
if you do a writeup on Pirate i'll gladly refund a portion of your purchase. we'd like to do it ourselves but we are doing all we can to keep up with orders at the moment .
Old 10-14-2011, 07:42 AM   #6 (permalink)
KyleQ's Avatar
Member # 83837
I would love to, but with a new house purchase money is to tight I can't even afford lunch today
Old 10-14-2011, 12:00 PM   #7 (permalink)
Member # 148051
i can't believe you bought a house before 3/4 ton disc brake brackets!
Old 11-16-2011, 08:05 AM   #8 (permalink)
Member # 91745
Got mine today. Thanks!
For the installation:
knuckle --> spacer --> bracket --> spindle OR
knuckle --> bracket --> spacer --> spindle?
Tellico Rally #866
SirFuego is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 10:37 AM   #9 (permalink)
Member # 148051
knuckle --> spacer --> bracket --> spindle -->
Old 11-25-2011, 04:56 PM   #10 (permalink)
Member # 87013
price on a set of dana 60 front brackets and weld on 14 bolt disk brake brackets shipped to 28079... Thanks
99 tacoma, tons, 42s, caged and beat to hell
Yotacrawlin is offline   Reply With Quote Quick reply to this message
Old 02-28-2012, 02:29 PM   #11 (permalink)
Member # 3074
Send a message via AIM to jeepbrew
Bump. I need these... PM price shipped to 35128 please.
95YJ - 5.0/NP435/NP205/5.13s/HP D60/Grizzly/Yukons/D60HD/Cryo'd shafts/Detroit/39.5"IROKs/110" WB
jeepbrew is offline   Reply With Quote Quick reply to this message
Old 05-18-2012, 09:17 AM   #12 (permalink)
Member # 199861
ttt
[SIZE="2"]
[/SIZE]
[CENTER][SIZE="4"]
540-532-2906
[/SIZE][/CENTER]
Cutthroat 4x4 is offline   Reply With Quote Quick reply to this message
Old 05-20-2012, 07:06 PM   #13 (permalink)
Member # 90103
Ford D60 front brackets shipped to 85373.
Thanks
And, I use my factory spindle?
jr84cj is offline   Reply With Quote Quick reply to this message
Old 07-14-2012, 04:25 PM   #14 (permalink)
Member # 33493
I got a pair of these the other day and was thinking.....
If you mount them knuckle --> spacer --> bracket --> spindle doesnt it push your WMS out 1/4" each side and mess with the spline engagement in the hub? Like 1/4" less then stock..... Will it still allow you to run a Snap ring on the end of the stub shaft?
Or am I over thinking this.....
Loudzr2 is offline   Reply With Quote Quick reply to this message
Old 07-27-2012, 11:12 AM   #15 (permalink)
Member # 148051
this kit does not affect spacing at all. in other words the new parts are the same thickness as the the old ones.
Old 08-25-2012, 11:29 AM   #16 (permalink)
Member # 191552
These things fit like a glove! You guys have some nice products! Thanks Laura and Rob!
JMDCUSTOMZJ is offline   Reply With Quote Quick reply to this message
Old 02-28-2013, 05:24 PM   #17 (permalink)
je1989's Avatar
Member # 140674
I've found that these don't fit the Reid knuckles without grinding a lot of material from the knuckle for the caliper to align with the bolt holes. Wish I would have known that. May try a different caliper tomorrow.
4400 Unlimited Class
Sponsors/Supporters:
Crossed-Up Offroad, Lucas Oil, PRP seats, Raceline Wheels
je1989 is offline   Reply With Quote Quick reply to this message
Old 02-28-2013, 05:45 PM   #18 (permalink)
over's tj's Avatar
Member # 107256
I like these, nice clean simple brackets, I also run Reid knuckles, any plans to make a set that fit without mods?
Anyone out there able to compare (pros/cons) using the GM single pistons to Factory pre ~92 dual piston? I have both old version and newer version of ford brackets with no calipers, trying to decided what direction to go.
FFR-FAB-'NEVERENDING BUILD' TJ, 4.0L, AW-4, Atlas,113"wb, hp60/14b, ARBs, 40s
over's tj is offline   Reply With Quote Quick reply to this message
Old 02-28-2013, 07:32 PM   #19 (permalink)
KyleQ's Avatar
Member # 83837
I know I'm late to the party, but does your offer still stand?
I'll do it right -
Kyle
Old 04-16-2013, 03:32 PM   #20 (permalink)
Member # 23988
Send a message via Yahoo to efibroncoman
Will you sell just a pair of the spacers for the Ford Dana 60(5 bolt) brake brackets? If so, how much to 95610?
1975 Ford Bronco stretched and linked
2003 Chevrolet Suburban 2500 4x4
efibroncoman is offline   Reply With Quote Quick reply to this message
Old 06-26-2013, 05:04 AM   #21 (permalink)
Member # 168481
mi xj is offline   Reply With Quote Quick reply to this message
Old 06-26-2013, 08:40 AM   #22 (permalink)
over's tj's Avatar
Member # 107256
Update? Did you try different calipers?
To seller, input on using with Reid (Ford) knuckles
Old 08-06-2013, 08:20 AM   #23 (permalink)
Member # 48895
can you PM me a price shipped to 28785?
ZJ buggy kinda thing...
aintlifegrand is offline   Reply With Quote Quick reply to this message
Old 05-26-2014, 07:37 PM   #24 (permalink)
ebk
Member # 120407
Quote shipped to 75460. your PM box is full
ebk is offline   Reply With Quote Quick reply to this message
Old 06-25-2014, 05:00 PM   #25 (permalink)
thelawman57's Avatar
Member # 136676
Need this: For Jeep JK Dana 60 swap info give us a call. The swap brackets for ABS equipped vehicles include a feature for holding the wheel speed sensor and use the stock 1 ton ford rotors
What's your number?
thelawman57 is offline   Reply With Quote Quick reply to this message
