Member # 132098
**NEW** Chevy 1 Ton Tie Rod End STEERING INSERTS from TMR CUSTOMS
We're just working on a huge run of these. They are CNC machined in-house on our Mazak QTS200 Turning Center. Tie Rod End Inserts - Chevy 1 Ton Taper - ONLY $6.95 EACH! CNC machined in-house from 1020 cold rolled steel Allows you to convert any existing taper to the common Chevy 1 ton tie rod end taper Perfect for over the knuckle steering conversions Requires drilling out your existing knuckle hole to 1" and welding in the insert Fits ES2234R and ES2234L chevy 1 ton tie rod ends Sold individually ![]()
TMR CUSTOMS YOUR PREMIER SOURCE FOR CUSTOM FABRICATION & OFFROAD ACCESSORIES! SPECIALIZING IN: Rod Ends & Tube Adapters - DIY/Builders Components - Transfer Case Support Kits - Gussets - Link & Shock Tabs - 3 & 4 Link Brackets and more.... Check us out on FACEBOOK! Online - www.tmrcustoms.com CALL US TOLL FREE @ 1.877.503.TMR1 (8671) |
Member # 132098
Thanks for the orders! Shop around....we're confident these are the best product for the best price.
Member # 132098
Let us know if you want to see another size TRE Insert similar to these. We've been getting lots of requests to make them in common Jeep tapers.
Member # 132098
Keep the orders coming...we can make them as fast as you can order them!
Member # 132098
Thanks for all the orders...these are quickly becoming one of our best sellers.
Member # 132098
Looks like we'll be running inserts to fit the larger drag link end taper soon...stay tuned!
Member # 132098
Just waiting on material to arrive, then we'll be running Tapered Inserts to fit the Chevy Drag Link Ends.
Member # 132098
Just added the Drag Link Inserts to our site. Click on the following LINK for more details!
Member # 132098
Thanks for the orders Pirate, our weld in tie rod end and drag link inserts are one of our best sellers!
Member # 132098
We shuffled these around on our website to clean some things up....
Here's the new link for the Tie Rod End Inserts Here's the new link for the Drag Link End Inserts
Member # 132098
**NEW** Chevy 1 Ton Tie Rod End & Drag Link End STEERING INSERTS from TMR CUSTOMS
You asked for it, and we listened! Next up is a Tie Rod End Insert with the factory Jeep taper.
#12 (permalink) |
Member # 132098
Keep the orders coming, we've got more bar on order and we'll be turning more of these next week on our Mazak CNC Lathe!
#13 (permalink) |
Member # 132098
These are one of our top sellers, so keep the orders coming. We've got a ton of stock and our Tie Rod End Inserts ship out same day!
