H1/Humvee/Split wheel parts - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 02-04-2012, 08:54 AM   #1 (permalink)
WINNAR!
Dookey's Avatar
Member # 23680
Along with our wheel and tire bit we also carry every part needed for the Humvee split wheels. We have O-Rings, valve stems, flange nuts, along with all the wheel halves or inserts.
That is one of the many cool things about Humvee wheels. If you need something, it is fairly easy to replace a part rather than the whole wheel. Did you swap out your axles for some one tons? Just replace the back shell with a new center with your new bolt pattern.
Did you roach an outer ring running your favorite trail? Have us weld in some rock rings and we will ship them straight to your door. Then you only have to swap out the outer rings over a few hours with no down time!
We stock each part required to completely rebuild your split wheels. We support them should you need any replacement part for them. If you need a wheel part give us a shot.
http://www.trailworthyfab.com/Hummer-Wheel-Parts/
Some hard to find parts:
Need 12 bolt pilot washers? We keep these on the shelf.
http://www.trailworthyfab.com/12-Bol...ot-Washer.html
Need replacement valve stem O-Rings? We have those too
http://www.trailworthyfab.com/12-Bol...nt-O-Ring.html
Did you add rock rings? We stock the 45 degree valve stem adapters
http://www.trailworthyfab.com/H1-12-Bolt-Hummer.html
One of the hardest parts to get your hands on is the replacement metal valve cores. We have them squared to go.
http://www.trailworthyfab.com/12-Bolt-Valve-Core.html
If you need any part for your Humvee wheels we have it! Post up if you need some parts and we will get you a freight quote. All of these parts can ship via FedEx to your door.
We are open 10am - 5pm CST so call the shop if you need a hand. 316.337.5311
We are open 24 hours a day at http://www.trailworthyfab.com/
TRAIL WORTHY FAB
Industry's Toughest Transfer Case
| 316.337.5311
