Dana 60 front 3/4 ton brake conversion kit - Page 13 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 11-10-2016, 06:38 AM   #301 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Originally Posted by powerranger33 View Post
Thank you @GubNi for the kit, just received it in the mail yesterday. Everything looks great and I can't wait to put it on.
Glad you like it.
Dana 60 or 14 bolt disk brake kits $315 shipped -->
Dana 70 kits $300 -->
. . Sterling 10.25 kits $390 -->
Dana 60 front 3/4 ton kits $295-->
GubNi is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 06:18 PM   #302 (permalink)
generalee7's Avatar
Member # 16522
Thanks for shipping mine out so quick!
generalee7 is offline   Reply With Quote Quick reply to this message
Old 01-01-2017, 09:52 AM   #303 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I try to get every order out the same day if possible.
Old 01-05-2017, 05:37 PM   #304 (permalink)
Member # 9461
Will the 3/4 ton kit listed in your sig work on a CUCV front 60? Thanks
The Frankenrover Saga
___________________________________________
- 110 wheelstand pritchet
FrankenRover is offline   Reply With Quote Quick reply to this message
Old 01-05-2017, 06:19 PM   #305 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Yes it works very well with those axles.
Old 01-11-2017, 07:24 PM   #306 (permalink)
Member # 162148
Have you done any research into a 3/4 ton setup for 2005+ Ford Dana 60's?
leeleatherwood is offline   Reply With Quote Quick reply to this message
Old 01-12-2017, 02:50 AM   #307 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I just got an 05 axle to start building a kit last week.
Old 01-12-2017, 07:55 AM   #308 (permalink)
Member # 162148
Awesome.
Consider a kit already sold.
Old 02-21-2017, 06:01 PM   #309 (permalink)
Member # 20525
I have an 85 dodge front d60. I bought a kit from you a while back...it didn't work for me. I did see where you were trying to get a bracket designed for the external hub axle....would your kit for the 90-93 dodge axle work for me..?
need brackets.
Thanks
85 toy, 22re, 5spd,5in susp lift,5.29's & detroit,ruf,chevys,longs,etc
poolman450 is offline   Reply With Quote Quick reply to this message
Old 02-21-2017, 06:03 PM   #310 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
need brackets.
Thanks
No the 90-93 is the same as Chevy. I have a older dodge hub and hope to make that bracket available in March or April.
Old 02-21-2017, 08:08 PM   #311 (permalink)
Member # 20525
Great! I'll keep checking back. cant wait to get a bracket so everything lines up right.
Old 03-27-2017, 07:01 PM   #312 (permalink)
delsolcharlie's Avatar
Member # 227618
...revised
delsolcharlie is offline   Reply With Quote Quick reply to this message
Old 03-28-2017, 06:51 AM   #313 (permalink)
Member # 227618
btt
Looking for a Dana 60 79' KP front kit.
Do you have a kit that is one piece and doesn't have the spacer?
Also do you sell one with the one set of holes for the oem/Reid knuckles.
Thanks!
Old 03-28-2017, 08:18 AM   #314 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Thanks!
Yes I have the kit in stock. The spacer is a 1/8" shim to make the stud shaft the correct length. You might be able to leave it off and shave the end of the stub shaft. Mine have two set of holes and fit all OEM and aftermarket knuckles including Reid and Crane.
Old 03-28-2017, 08:37 AM   #315 (permalink)
Member # 227618
Sent PM
Old 04-07-2017, 06:50 PM   #316 (permalink)
Member # 748073
So I have a 92 Dodge before I found this form I bought me the plates to put Chevy calipers on my truck. I have the plates and calipers but I don't know what rotors to use I need someone Chevy rotors that are a 8 on 6.5 lug pattern but for 1/2 lugs a part number or anything that could help would be very appreciated thanks
Brycepreece96 is offline   Reply With Quote Quick reply to this message
Old 04-08-2017, 10:28 AM   #317 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I'm not sure what plates you bought, but most of us use 3/4 ton chevy front rotors. Try a rotor from a 1986 chevy K20.
Old 04-08-2017, 05:14 PM   #318 (permalink)
Member # 748073
I bought the plates from tmr custom they use calipers from 80's Chevy's
Old 04-10-2017, 08:15 AM   #319 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
They use the standard Chevy 3/4 ton rotors also.
Old 04-21-2017, 07:27 AM   #320 (permalink)
MtnYota's Avatar
Member # 83913
How are the 05+ Superduty Kits coming?
'85 Xtra Cab 3rz,Duals, D60/14b, Detroit front/rear, 35spline chromos,rears/chevys, bad temper
MtnYota is online now   Reply With Quote Quick reply to this message
Old 04-24-2017, 03:21 PM   #321 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Slowly, I wish I had more time to devote to developing new kits.
Old Yesterday, 06:38 AM   #322 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
btt
