Chassis Unlimited Complete Line of CNC Machined Dana 60 Steering Arm Kits.
This is not something new, But yet a More Complete Version, then what you normally see available.
These Kits and Arms are IN-STOCK For Same/Next Day Shipment At all Times!
Our Arms are made 100% In House on our CNC Milling Machines, And are Manufactured with USA Materials, In Livermore California. All of these kits are In-Stock, Ready to ship at all times.
Features Include-
-Spring Less Design Dana 60 Steering Arms
-CNC machined from 1018 cold rolled steel
-10 degree Tie-rod end angle correction
-Tapered for the 7/8" Chevy 3/4 ton Tie Rod Ends or can be drilled out for 3/4 hiem joint(No Charge)
-Machined with 5th hole for Reid Racing knuckles( If your knuckles do not have a 5th stud, you may run with out it.)
Our Steering Arm Kit's Include-
-2 Adjusting screws and jam nuts
-2 Springless adjusting washers
-2 nylon bushings
-2 Zinc plated zerk fittings
-ARP Mounting Studs/hardware (10 ARP 1/2" fine thread studs and tapered nuts)(Includes Hardware for 5th Stud)
We Offer The Arm Kits in 3 Different Configurations-
-Short Arm Kit(Single Hole Both Sides) - $249.99
-Short/Long Kit(Used for Cross Over Steering W/High steer, Single Arm and A Double)- $259.99
-Long Arm Kit(Both arms Have Double Holes) - $269.99
-Drill Holes Out to 3/4 For Hiem Joints- $FREE
Complete Cross over and High Steer Kit Includes-
-Left And Right Springless D60 Steering arms
-Tie Rod Kit (2X-54" 1.5"x.250" DOM Tube), With Chevy TRE Tie Rod Ends(2X- ES2234 R/L, ES2026R, ES2027L), 7/8-18 Tube Adapters, and Jam Nuts
-2 Adjusting screws and Jam nuts
-2 Replacement nylon bushings
-Arm Mounting hardware (10 ARP Chromoly 1/2" fine thread studs and tapered nuts)(Includes Hardware for 5th Stud)
-$493.99
Complete Cross over Kit Includes-
-Passenger Side Springless D60 Steering arm
-DragLink Kit (54" 1.5"x.250" DOM Tube), With Chevy TRE Tie Rod Ends(ES2026R, ES2027L), 7/8-18 Tube Adapters, and Jam Nuts
-Arm Adjusting screws and Jam nut
-Springless adjusting washer
-Zinc plated zerk fitting
-Arm Mounting hardware (5 ARP Chromoly 1/2" fine thread studs and tapered nuts)(Includes Hardware for 5th Stud)
-$246.99
We Also Offer Dana44 kits, Tie Rod Kits, Pitman Arms, And Tons More.
Purchase them Directly From our Web site, and Get more info, Here-
ChassisUnlimited.com/product/Steering
Or Call us @ 888-552-5371
Dont Forget to Follow Us on FaceBook For Updates and Specials- HERE
Dealer Programs Available for all of Chassis Unlimited Products, Call for Details.
Features Include-
-2 nylon bushings
-$493.99
-$246.99
