If you are looking for a performance rear axle option but you are on a budget we have an awesome new kit.
The Torq 14 Bolt Resurrection JK Kit is the perfect solution to put a bullet proof 1-ton rear axle under your ride without breaking the bank.
What it is-
The kit is simple. We provide you with a new fabricated axle housing complete with spindles and a Torq-14 3rd member. The JK Kit adds JK brackets welded and tone rings. All you need is a single rear wheel 14 bolt axle (Early to 1998). This kit allows you to reuse the axle, shafts, hubs, adjuster nuts, pinion support, carrier and gears out of junkyard 14 bolt.
The benefits-
There are a number of benefits with this kit but here are the big one. The Resurrection Kit eliminates the need to shave your 14 bolt (housing or gears) The JK kit allows you to bolt the axle housing into your JK. This eliminates a ton of fabrication headache in doing a shave job and the possibility of having the shave job leak. Many of the donor axles are equipped with 4.10 gears, as well, which saves you money on regearing costs on your JK. Once the axle is built, the complete package is near Dana 80 strength while weighing much less. Beyond these benefits you are getting axle design and technology that has been developed over 4 years of King of the Hammers / Ultra 4 racing specifically designed for off road abuse.
The cost-
$2395 Standard 14 Bolt Resurrection Kit (No Brackets or Tone Rings)
$3120.95 JK Kit (Includes JK Brackets & Tone Rings) (EDIT): JK Price below includes rear brake brackets. Our brake brackets work with Eldorado '76 to '78 calipers.
Torq Fabricated Axle Housing shown with JK Brackets & Spindles
Torq 52 tooth Tone Rings
Torq-14 Nodular Iron 3rd Member
Torq Standard Fabbed Housing with Billet Spindles
What it is-
The benefits-
The cost-
