Dynatrac: Front only Pro Rock d44/60 Hydrid and Pro Rock D44 - $7650.40 shipped as configured no "Upgrades" listed below are included.
CA residents add $509.63 tax
This is the way to go if you want the HD front axle and no worries on a LCG rig. The full sized D60 will not fit in the TJ with less than 3.5" of lift. 3.5" is really the bare minimum lift for a 60.
Complete Custom Dynatrac Pro Rock 44/60 Hybrid Front Axle Assembly - '97-06 Jeep TJ
General Dynatrac Axle 1 Custom Machined Dynatrac Pro Rock 44 High Ground Clearance, High Pinion (Reverse-cut) Heavy Duty Nodular Iron Housing
General Dynatrac Axle 1 Heavy Duty 3.125" Diameter x .50" Wall DOM Axle Tubing, Installed
General Dynatrac Axle 1 Matched Housing Geometry, Pinion Angle, and Wheel Alignment for Vehicle's Suspension
General Dynatrac Axle 1 Axle Width - 63.50" (Min.)
General Dynatrac Axle 1 ARB Air Locker Differential, D44, 35 Spline, Installed, w/ARB Kit
General Dynatrac Axle 1 New Generation JK D44 Ring and Pinion, 5.13 Reverse-cut, Installed
General Dynatrac Axle 1 Input Yoke, D44, 1310 U-Bolt Style, Installed, w/Yoke Kit
- (Upgrade to 1350 Yoke = $29.00)
General Dynatrac Axle 1 Heavy Duty 35 Spline, 1.5" Diameter USA-Grade 1541H Alloy Inner and Outer Axle Shaft Assemblies w/Spicer 1480 U-Joints, Installed
- (Upgrade to RCV Performance 4340 Chromoly CV Axle Shaft Assemblies w/RCV's Lifetime Warranty = add $1,695.00)
- (Upgrade to Competition 4340 Chromoly Axle Shaft Assemblies w/CTM U-Joints = add $1,295.00)
General Dynatrac Axle 1 Warn Premium 35 Spline Locking Hub Assemblies, Installed
- (Upgrade to Dynatrac Heavy Duty Dynaloc Manual Locking Hub Assemblies = add $429.00)
General Dynatrac Axle 1 Dynatrac Pro Series 60 Heavy Duty Wheel End Package, Installed (Includes Dynatrac's HD Forged End Forgings, Nodular Iron Knuckles, Chromoly Spindles, Nodular Iron Wheel Hubs, and Serviceable Timken Bearings)
General Dynatrac Axle 1 Wheel Bolt Pattern - 5 on 5.5"
General Dynatrac Axle 1 Dynatrac Stub Hub Conversion Kit, Installed - Optional Upgrade = add $349.00
General Dynatrac Axle 1 Heavy Duty Dual Piston, 13.25" Vented Rotor Disc Brake Assemblies (17" Wheel or Larger Required), Installed
General Dynatrac Axle 1 No Steering
- (Dynatrac Billet Steering Arm, RH or LH, Optional Upgrade = add $149.00 ea.)
- (Dynatrac HD Tie Rod Assembly, Optional Upgrade = add $329.00)
General Dynatrac Axle 1 Dynatrac Heavy Duty Jeep TJ 3/16" Coil Spring Suspension Brackets, Installed
General Dynatrac Axle 1 Dynatrac Pro Rock 44 Nodular Iron Powder Coated Diff Cover, Installed
General Dynatrac Axle 1 GL-5 Gear Oil, Installed
General Dynatrac Axle 1 Axle is Detailed and Painted Dynatrac's Signature Gloss Black
6+ weeks to build then ship. PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business. When replying please include all previous messages in PM (keeps a running conversation).
Namaste,
Allen
Namaste,
Allen
