Our JK Rear Axle Bracket kit is designed to work perfectly with 3-3/8" to 3-1/2" axle tubes. If you are looking to sling an axle bigger than a Dana 60 under your JK look no further. Our kit is designed specifically to work with GM 14 Bolt axle housings but will work with any axle housing with 3-1/2" axle tubes.
Laser cut and CNC formed 3/16" mild steel.
$395 - Torq JK Bracket Kit (Brackets Only)
$554 - Torq JK Bracket Kit with 52 tooth Tone Rings Included
Torq JK Bracket Kit - $395 (Brackets only)
Torq JK Bracket Kit with Tone Rings - $554
