New Nitro Gear packages for your vehicle, now with 1 part number!
Nitro Gear and Axle has led the way for many innovating R&P and axle packages. Now they have simplified the way you purchase gears. With one part number you can purchase your front and rear ring and pinions, master install kits, solid preload spacers, and new yokes if they are required. No more searching around to find the correct install kits and ratios for both your axles!
Do you really need new gears in your axles?
It is a common misconception that Re-Gearing a vehicle is only for Hardcore Off-roaders or for huge oversized tires. In fact, most of the late model vehicles we produce aftermarket ratio’s for are daily driven vehicles with slightly oversized tires. In an effort to improve fuel economy, Late model overdrive transmissions are geared very high which means RPM’s are very low on the highway. When even a slightly taller tire is installed the RPM’s are reduced below acceptable levels that the engine was designed to run. This causes constant shifting out of overdrive, sluggish acceleration, poor economy and rapid wear on the transmission and other components.
By changing the Ring & Pinions in your vehicles differentials, you can match the ratio to the tire size to bring the RPM’s back to where the manufacturer intended. Typically it is recommended to select a ratio slightly lower (higher numerically) than what the math will tell you. This will help accommodate increased rolling resistance, wind drag, and added weight of aftermarket accessories and gear.
If you have any questions or need a quote, contact us
I need a quote for the following delivered to 28376-
88 and down 14bolt 5.13 gears for a 4.56 carrier-pn GM14T-513-NG
14bolt master install kit- pn MK GM14T-A
14bolt 1350 YOKE - U-BOLT STYLE- pn YOKGM14T-1350-U
78 High pinion dana60 5.13 gears for a 4.10 carrier-pn D60R-513R-T-NG
Dana60 master install kit- pn MK D60-F
those part numbers are for Nitro gear, if you have better deals on other brands just let me know.
Here are some of the popular Toyota packages. They include everything you need to re-gear the front and rear axles of your Toyota:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
1991-1997 Toyota Land Cruiser 70 & 80 Series Front & Rear Gear Package Kit:
I've got an 89 Bronco 2 with the TTB Dana 35 front and Ford 8.8 rear. Can you get me a price for a set of 4.56's for my truck. Shipped to 70037. Thanks!!!
Nitro Gear & Axle Gear Packages for many popular applications are in stock. One Part Number includes everything you need to re-gear your 4x4.
Many applications including Toyota FJ Cruiser, Land Cruiser, Tacoma, Tundra. Ford Super Duty, GM Duramax, Dodge Cummins, Jeep YJ, XJ, TJ, ZJ, WJ, WK, JK and many more. You can find them here:
Ive got a 60/sterling from an 89 f350 im looking to regear to 5.38. They have 3.55 gears now so ill need thick cut front gears. Price on gears and install kits shipped to 26582. Thanks.
