http://diy4x.com/product.php?productid=17798&cat=249&page=1
Fully machined right here in house from a 2" x 3.5" billet of solid steel. 2" thick helps keep the interference between the leaf spring and cross over drag link in check. Designed to use the ES2026 and 2027 Drag link ends for the best angles. 5th stud hole for use with Dedenbear knuckles.
10 degrees kingpin inclination correction to take the angle off your drag link ends.
Top of the arm is engraved with our logo and U.S.A.
ARP steering arm studs!
Mating high steer arm,
http://www.pirate4x4.com/forum/axle...cross-over-steering-arm-kit.html#post21272290
Kit includes the arm, 4 studs, 4 conical seat nuts and a grease zerk or you can choose the option for the 5th stud and conical seat nut. Choose the 5 stud option for your Dedenbear knuckles.
