New Knuckle and C-shape With Unit Bearing And Drive Flange!!!!!!! Will fit 47 Spline RCV or Ouverson Shafts!!!!!! These things are huge and strong. The ball joints are larger than 60 ball joints. Uses a bolt on drive flange with 8x6.5 Bolt Pattern. Everything is brand new!!! Base price with no high steer and no brakes is $2,000 Call for more info. 616-696-8114
what are they based off of, what would i use to get replacement parts as a base at NAPA or a local place and what type of over the counter type brakes can be used or just aftermarket?
Can you share any pictures of these installed on an axle with said 47 spline axles installed? Curious as to how much clearance remains between yoke and balljoints with a Rockwell u-joint shaft in place.
I'm interested in the answer to the brake question as well.
Also...any recommendations with regards to wheel diameter / backspacing limitations? Or is that pretty much just a function of the user's choice of brake package?
