DIY 4x :: Steering :: Tie Rod Clamp
Designed to fit 1.5" and 1.375" tie rods. For the purpose of attaching a mounting point for a hydraulic cylinder to your tie rod without having to weld them on. This allows for changing your toe in adjustment in finer degress. No need to make full turns on the tie rod to keep the mounting tabs on the appropriate side.
If you'd like, we can also make the tab or tabs that need to be welded to this to mount for the cylinder and weld them on for you. We make quite a wide variety of mounting tabs for this purpose. Anywhere from a 5/8" pin on up to a 1 1/8" diameter pin. We make them both in a clevis or tab form from 3/8" thick on up to 1 1/8" thick steel.
Or course we can also help you mount the other end of the cylinder. Be sure to check out the related products tab to see our diff covers that have a mounting point built into them. A very popular option. Now your hydraulic assist cylinder mounting is a simple bolt on affair.
