Just finished this new arm today. It is a newer version of my standard arms with tie in kit. They are a combination of my thick milled arms and my tie in arms. so now you can have the best of both worlds. 3/4 Hardware for knuckle tie in kit is included.
$200 to your door.
What you will get:
1 pair of arms (1 pass 1 driver)
2 Pcs of 3/4 x 10" Grade 8 Bolt w/ nylock nut
2 pcs of 3/4" ID DOM
1 Springless conversion ( set screw, jam nut, and custom thick washer)
ARMS CANNOT BE PRE-DRILLED FOR TIE IN BOLT. ALL FACTORY KNUCKLES ARE SLIGHTLY DIFFERENT. YOU WILL NEED TO INSTALL THE ARM AND THE TIE IN BOLT LIKE IN THE PICTURE TO MARK THE LOCATION ON THE BOTTOM OF THE ARM AND THEN REMOVE AND DRILL.
I CAN DRILL LINKAGE HOLES FOR YOU. FOR HEIMS OR GM TRE.
YOU CAN ORDER DIRECT FROM MY WEBSITE HERE! Four Wheel Supply - Dana 60 thick Milled High Steer arms with Knuckle tie in kit
These arms are also avail in a double ended arm.
Order them direct from my website here: https://www.fourwheelsupply.net/pro...illed-high-steer-arms-with-knuckle-tie-in-kit
$200 to your door.
What you will get:
