Yukon Ring & Pinion Sets and Grizzly Lockers
I'm having a special on all Yukon Ring & Pinion sets, Master Overhaul Kits, and Grizzly Lockers.
Yukon Ring & Pinion sets give you the confidence of knowing you're running gears designed for the harshest of conditions. Whether it's on the street, off-road, or at the track; Yukon ring & pinion sets deliver unrivaled performance & quality. Yukon uses the latest designs and manufacturing technologies to provide a quiet running gear that is strong and easy to set up. All Yukon ring & pinion sets come standard with a one-year warranty.
Yukon Master Overhaul kits give you all the high quality parts you need to start & finish every differential job. Yukon offers more tailor-made kits than any other manufacturer in the industry to meet your specific installation needs. This kit uses Timken bearings and races along with high quality seals and small parts. Included in this kit are carrier bearings and races, pinion bearings and races, pinion seal, complete shim kit, ring gear bolts, pinion nut, crush sleeve (if applicable), oil baffles and slingers (if applicable), Thread locking compound, marking compound with brush, and gasket. Yukon's Master Overhaul kits are the most comprehensive and complete kits on the market. They do extensive research to ensure that every kit is specially tailored to your application.
