99-04 Stock Dana 60 Front Unit Bearing Hub Machined to accept 35 spline axle's, smaller brake rotors, and your choice of bolt pattern. Bolt patterns will be drilled and tapped 1/2-20 and screw in studs are included. (not pictured) Inner spindle will be bored out to 1.5625" and inner spindle bearing pocket will be machined to accept standard D60 35 spline spindle bearings.
You can view and buy direct here on my website.
Four Wheel Supply - 99-04 Dana 60 Modified Unit Bearing Hub
Using only Timken bearings!
