40 spline 14 bolt steel spool from Nitro gear.
$295
GM 14 Bolt, 10.5", Full Float
40 Spline, Nitro Light-Weight Steel Spool
Differential: GM 14 Bolt (10.5") & Torq 14
Gear Ratio: 4.10 & Down, Any A/M Thick
Axle Splines: 40 (req. upgraded axles)
Ring Gear Bolts: 12 (included)
Manufacturer: Nitro Gear & Axle
Warranty: Lifetime
Tech Note:
40 spline is an aftermarket upgrade. All of the vehicles listed will require new 40 spline axle shafts!
GM 14 bolt - 10.5" is identified by the removable pinion support.
Works with Torq-14 and load bolts!
Nitro spools are the ultimate in traction and strength for racing and off-road use. Each spool is CNC machined and heat treated to ensure precise fit and uniform strength. Our one-piece design withstands high horsepower and has no moving parts. With our new, improved design you can expect this spool to be nearly 10 lbs lighter!
$295
Warranty: Lifetime
Tech Note:
