FREE Heavy Duty Front and Rear Differential Covers with Front and Rear Ring and pinion purchase!
Ring and Pinion
- 5 Year Warranty
- Computer Heat Treated 8620 Steel
- Manufactured To O.E. Specifications
- Double Shot Peened
- Double Lapped
Master Install Kits
- Pinion Nut
- Pinion Seal
- Timken Outer Pinion Bearing And Race
- Crush Sleeve
- Timken Inner Pinion Bearing And Race
- Pinion Shims
- Carrier Shims
- Carrier Bearings And Races
- Ring Gear Bolts
- Thread Locking Compound
- Gear Marking Compound
- Silicone Sealer
Heavy Duty Differential Covers
- Cast From Lightweight Aluminum To Dissipate Heat
- Raw Aluminum Finish
- ReinForcing Ribs For Added Rigidity And Strength
- Heat Treated And Shot Peened To Help Handle A Direct Impact
- Fully Machined Seal Surface For A Leak Free Installation
Contact us today at Baseline 4x4 Outfitters to get your quote today!
Ring and Pinion
- 5 Year Warranty
- Double Lapped
Master Install Kits
- Pinion Nut
- Pinion Seal
- Crush Sleeve
- Pinion Shims
- Carrier Shims
- Ring Gear Bolts
- Silicone Sealer
