***BCB D-44 Rear Disk Brake conversion rotors!*** - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 04-21-2005, 01:49 PM   #1 (permalink)
The Fleckster's Avatar
Member # 3178
Here they are. These rotors will fit the Scout 2/IH Pickup Dana 44 rear axle when doing a rear disk conversion.(should fit all Dana 44 axle flanges that are 7.25" or smaller in Diameter). They are CNC machined 5 on 5.5" bolt pattern with the holes the exact size of the stud threads so they center and eliminate making the rear wobble. They have a counter recess on the back side to allow for the non threaded portion of the stud to sit so the rotor sits flush
BCB will sell these for the do it yourselfers but these are included in our weld on, rear disk brake kit that will be available next week.
Rear disk is the only way to go with larger tires and in the wet conditions.
Other Companies sell a similar rotor that will work but at $90 each
Your cost on these is $75 each or $150 a pair.
John
Back Country Binders 4x4 ( bcb4x4.com )
The Fleckster is offline   Reply With Quote
