Member # 3178
DOT Stainless Steel Brakelines *cheap*
Our New line of D.O.T. approved BCB Stainless Steel Braided Brakelines are done. These are better than most inferior brands because they have the clear protective cover, and the fittings are all Steel rather than softer brass that may strip. In addition we have eliminated some threaded joints (use more universaly by switching ends keeping same lines for many applications.) that were brass and prone to stripping if overtightened. The steel is way more forgiving. These lines give more abrasion resistance, better tear resistance due to snagging, and most importantley more line pressure due to less line swelling
Coolest Feature is the IH colors. One end is RED and the other is BLACK Colors for custom lines are Red, Black, Blue, and Grey. We currentley have patternes and correct lengths for all Scout 80, Scout 800, and Scout 2/Traveler applications. We have these in stock length, extended length, and CUSTOM length. If you have a line that needs to be made, please contact us and we can custom build your spec. Each line is DOT approved and tested at 30,000 psi for 10 seconds for leaks. FYI most brake systems are 2-3000 psi. Please call for pricing on other applications but most will be similar priced. I may require old ends cut off lines that you are adapting to insure correct fittings on your new lines mailed to me. Scout 2 Front Disk or Drum $75 a set Scout 80-800 front $75 a set Scout 61-80 Rear $40 each. Scout 2 Rear Disk Brake jumper lines $55 a set w/banjo bolts and washers Scout 2 axles to Scout 800 proportioning valve switch over conversion Line $40 International C & D series pickups and Travealls coming soon!! So please don't buy big companies or any other competitors lines when you can pay the same price or less, support a smaller Pirate vendor, and have a better product!!
John Back Country Binders 4x4 ( bcb4x4.com ) |
Member # 3178
***Give us a call today at 360-377-4979***
Here is a shot of our Dana 44 rear disk brake jumper lines
Member # 3178
***give Us A Call Today At 360-377-4979***
A shot of our Scout 80/800 drum front lines. We can put Scout 2 disk brake ends on these for Scout 2 axle swaps in the older Scouts!!
Member # 3178
The Rear Jumper lines are $55 a pair and are 9" long. If you need them longer we can custom make a set up for an additional $10(standard custom upcharge).
Member # 16680
do you make any lines for a superduty? need some that are longer than stock by say 4 to 6"
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club |
Can I get a price of a couple 25" lines with a 3/8 going to a 78 Waggy Dana 44 shipped to 23464? Thanks
93 toy x-cab d44 sas [SIZE="7"][COLOR="Cyan"]BUY MY TRUCK FOR $5000 OBO[/COLOR][/SIZE] [url]http://pirate4x4.com/forum/showthread.php?t=586599[/url] |
#12 (permalink) |
Member # 32939
this guy has a great deal and you should all check it out. he has done an outstanding job helping me out.
Just enough mods to live of a military pay check and ramen noodles. [URL=http://www.imagestation.com/member/index.html?name=bryan.robe&c=201]my photo album[/URL] |
#15 (permalink) |
Member # 187281
ok i have a 72 scout with chevy 60 in the front and 14 boltff in the rear need a price for a full set of lines it clears 39 in rubber couldint give u a lift hight but can put a tape on it and give ya whatever lengths u need can u give me a idea on a price
