It's sale time! Gears, Lockers, Install kits!! - Page 127 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 02-01-2011, 10:03 PM   #3151 (permalink)
Member # 181936
also interested in what youve got lockright (or similar) wise for the chrysler 8.25 27 spline
Hoooper is offline   Reply With Quote
Old 02-02-2011, 01:00 AM   #3152 (permalink)
Member # 168581
1984 toyota 4 cylinder 8 inch 5.29s two sets and install kits. can you get the yukon zip lockers as well? 98936
icon45acp is offline   Reply With Quote
Old 02-02-2011, 06:58 PM   #3153 (permalink)
firstcruise79's Avatar
Member # 134811
rear arb locker for 79 fj40
firstcruise79 is offline   Reply With Quote
Old 02-03-2011, 11:41 PM   #3154 (permalink)
Member # 100993
Send a message via MSN to riberware
can you get custom size Toyota chromoly rear axle shafts? these are for a HJ75 LandCruiser pickup... semi floating, 30 splines 21" short shaft, 33" long shaft... 6 on 5.5" bolt pattern.
[B]1983 Jeep CJ7[/B]:[SIZE="1"] CUCVaxles, 43"TSL/SX, 17" KMC beadlocks, ARB front, Detroit rear, 4.56ratio, D300 w/32spline outputs+1410 yokes, NP435 Granny, Chevy 383 stroker, Warn M8274+Warn M8000 rear, etc[/SIZE]
[B]1998 HDJ-80 LandCruiser[/B]: [SIZE="1"]37" MTR tires,17" Enkei wheels,4.88ratio,1HD-T Engine,snorkel, 4" OME lift[/SIZE]
riberware is offline   Reply With Quote
Old 02-05-2011, 06:25 AM   #3155 (permalink)
Member # 175879
D60 5.38 for chevy kingpin 60
D60 master kit
D60 Detroit locker
14 bolt 5.38 Thick
14 bolt master kit - old style (not slip on drums)
Shipped to 04093
Uh Oh is offline   Reply With Quote
Old 02-05-2011, 07:36 AM   #3156 (permalink)
Member # 135874
locking hubs for a 99' f250 sd w/d50 shipped to 93225
77 j10 6.0 4l80e 203/205 doubler 60s 37s
LYRCH is offline   Reply With Quote
Old 02-08-2011, 11:37 AM   #3157 (permalink)
CCOR's Avatar
Member # 48630
PMs Sent
Check your PMs for price quotes. Thanks!!
Best Price Guarantee or we Beat it!
www.classiccityoffroad.com
706-207-4140
Randy's Gear Supply Randy's Gear Supply.com855-572-GEAR
Find us on Facebook!!
Custom Cages, Chassis, 4 link and more at CCOR!
CCOR is offline   Reply With Quote
Old 02-09-2011, 09:12 AM   #3158 (permalink)
Member # 147031
Could i get a quote for d30 lockers ?
I'm looking at Powertrax NoSlip and Ox (wire-selectable)
Thanks
Fudpucker is offline   Reply With Quote
Old 02-10-2011, 06:59 AM   #3159 (permalink)
CCOR's Avatar
Member # 48630
PMs Sent
706-207-4140
Old 02-11-2011, 10:21 AM   #3160 (permalink)
ccb78's Avatar
Member # 138486
Can I get a price on a detroit for dana 60 35 spline and an install kit for 4.10 gears shipped to 47591. thanks
ccb78 is offline   Reply With Quote
Old 02-12-2011, 06:58 AM   #3161 (permalink)
Member # 107796
Needing a spool for a rear D60 30 spline,, Or should I just get the 35 spline and save for shafts?
Mud_Bogger is offline   Reply With Quote
Old 02-12-2011, 11:50 AM   #3162 (permalink)
Seven M's Avatar
Member # 101330
Quote for 5.86 gears, Detroit, and install kit for GM D60 front.
Shipped to CA 95961.
Seven M is offline   Reply With Quote
Old 02-15-2011, 10:21 PM   #3163 (permalink)
Member # 165754
ox locker for a dana 60 78-79 FORD front. shipped to 95076 CA thanks
ford250man is offline   Reply With Quote
Old 02-15-2011, 11:00 PM   #3164 (permalink)
Member # 174421
quote for HP30 and chrysler 8.25 4.10s and install kits and a carrier for the 30 to 57703
thanks
flushpuppyTRB is offline   Reply With Quote
Old 02-16-2011, 06:56 AM   #3165 (permalink)
Member # 29848
hp 60 5.13 detroit locker and in stall kit 35 spline ship to 48064
roger201 is offline   Reply With Quote
Old 02-17-2011, 11:38 AM   #3166 (permalink)
CCOR's Avatar
Member # 48630
PMs Sent
Check your PMs for prices. Thanks!!
706-207-4140
Old 02-17-2011, 12:04 PM   #3167 (permalink)
Member # 143296
need a set of 5.13 for dana 60 and 14 bolt. Shipped to Anchorage Ak. Also a Dana 60 open carrier for 4.10 and up. As well as install kits for both.
Success is the sole earthly judge of right and wrong.
nedmac_ynnad is offline   Reply With Quote
Old 02-18-2011, 10:22 AM   #3168 (permalink)
CCOR's Avatar
Member # 48630
PMs Sent
706-207-4140
Old 02-18-2011, 11:12 AM   #3169 (permalink)
Newbie
Member # 111685
i need 5.13 gears and install kits for a hp d60 and a corporate 14bolt with 10.5 ring. i would also like a grizzly locker for the 14b and a truetrac for the d60. shipped to 99207. thanks
Kakmix is offline   Reply With Quote
Old 02-18-2011, 11:23 AM   #3170 (permalink)
Member # 156326
Looking for a full rebuild kit for a dana 30, 4.88 gear, reverse cut to 79424
Looking for install kit for dana 44 out of a jeep, 4.88 gears to 79424
bigandrich44 is offline   Reply With Quote
Old 02-19-2011, 06:57 PM   #3171 (permalink)
Member # 153289
Toyota 5.29 reverse rotation, detroit, master install to 80634 zip please
97Tacoma is offline   Reply With Quote
Old 02-21-2011, 11:20 AM   #3172 (permalink)
CCOR's Avatar
Member # 48630
PMs Sent
706-207-4140
Old 02-23-2011, 12:28 PM   #3173 (permalink)
Member # 181936
do you carry aussie lockers? If you do, can you beat the $310 shipped from knowwheretojeep.com for a 29 spline chrysler 8.25?
Old 02-23-2011, 03:31 PM   #3174 (permalink)
Member # 5829
Need R&P 3.73 with install kit
Application 2002 F250 Sterling 10.25
Thanks-
DO NOT FEED THE HUMANS
They will not learn to take care of themselves.
0ILBURNER is offline   Reply With Quote
Old 02-23-2011, 06:34 PM   #3175 (permalink)
Member # 151546
DET187C-145A
8.8 detroit locker 31 spline for 4.56 gears to 20155
thanks
jay12 is offline   Reply With Quote
