Member # 6430
We have just released the D60 outters for Fords and Chevy's. Shipping Monday for 300 bucks a pair. Inners are coming but there out a few weeks.
10 year, no questions asked warranty. Let us know if you have any questions. Limited supply since it's the first production run so get yours today.
Roundeyes.com OutbackToilets.com |
Member # 21211
Any idea on pricing for inners on a chevy D60??
buggy with 404's 5.0 HO and a 4-speed [quote="Poohbair"]...because I am white trash I think I actually did say "fuck... look at that..."[/quote] |
#7 (permalink) | |
Member # 6430
#8 (permalink) | |
Member # 21914
Correct. 44's are in stock for Jeep applications, with blanks, GM and Ford on the way. Same warranty! Thanks, Ron |
#9 (permalink) | |
Member # 21914
Update 7-19-05
The tire diamater is just a part of the equation when it comes to loading or breaking a shaft. Here's what we do. Use the best material that is reasonably priced, forge it properly, machine and heat-treat to the correct specs. Once we've done that, we know we've made these shafts as strong and durable as possible without going to real exotic materials. Bottom line is there just isn't anymore to be done with Chromoly. So if you can break them, so be it - we did everything we could, so here's another shaft. UPDATE: As of 7-19-05 - I am out of Ford outers as of for about 4 weeks. Still have some GM in stock. ALSO - I have finished inners to make a "TJ" style front 60 - 31.25" and 16.15", 35 spline. Blanks on the way for custom work, about 4-weeks out. Thanks, Ron Ron Last edited by Racing Ron; 07-19-2005 at 03:13 PM. Reason: Updated info 7-19-05 |
#10 (permalink) | |
Member # 6430
Inners for the TJ or a custom application of around 60.750 inches FTF are available.
#12 (permalink) | |
Member # 29332
Still have any D60 35 spline outers for chevy? steve@tgtwoffroad.com
[I]'Extreme' seems to be a moving target...I may never get there.[/I] 84 CJ "Tripod" One ton 60/14b, 5.0 HO, 331:1 crawl, 39.5 Iroks...just the basics 97 TJ - 35's, 4:1, HP D30/8.8 and too much lift - the wife's daily driver 02 TJ - Under the knife-gettin' 60/14, w/40's 02 F350 - The grocery-getter |
#13 (permalink) | |
Member # 6430
Please call to get your order place in line. Limited supply shipments coming in and all backorders are filled first.
#14 (permalink) |
Member # 21914
Off the shelf parts WIN UROC Championship!
These are the same parts Lovell Racing (Modified Stock #232) used to win the UROC National Championship! No special one offs - these are the exact same parts you can buy.
Dual heat-treated rear Chromoly shafts. Dual heat-treated front Chromoly shafts. Quantities are limited for the next 4 weeks - but they're worth the wait. |
#15 (permalink) | |
Member # 6430
#16 (permalink) |
Member # 6892
so what applications do you have for d44 stuff? Looking for a pair of chevy d44 outers, an 80's jeep waggy longside, and a 77-79 ford f150/bronco shortside. IF you guys make those parts what would that set cost?
Yarr! I've been to the Hammers... There in the tool section at Home Depot. Rally for The Hammers post #141 Rally for Tellico post #100 |
#17 (permalink) | |
Member # 6430
#18 (permalink) |
Member # 28177
Do you have a set of 35 spline alloy 9" semi-float shafts? I have a 67" WMS housing from a ford van. I don't know the length of each shaft but they are equal length.
I'm interested in a set of these. |
#19 (permalink) | |
Member # 6430
#20 (permalink) |
Member # 28177
Thanks for the info. I can't go that narrow because I have the stock jeep frame and 39.5 tires
I do have a friend though that would love a 61-62" width and is thinking of building a rear blown out 9". can you pm me the price on the 35 sline cromo shafts for the application you are talking about?Thanks |
#21 (permalink) | |
Member # 6430
#22 (permalink) |
Member # 752
thanks , bruce
Wearin my alloy USA shirt right now , pretty sure its making my junk stronger
thanks , guys (Bruce/ Ron)
got a jeep and a yota. I hate myself.......Wrong Way Wheelers. Camino, CA |
#23 (permalink) |
Member # 745
OK now im drooling, you hooked up garbageman and now I want some. Can I get a quote on full with kingpin D60 35 spline inners and outers w/ t-shirt
1979 Toyota LS1, TH400, Stak 3 speed, D60/14 Bolt, 42" IROK's |
#24 (permalink) | |
Member # 6430
