Member # 48583
Dana 60,70,80 35 spline alloy full float shafts
Now in stock!!!! YUKON alloy rear Dana 60, 70 and 80 35 Spline full foat shafts in 3 different cut to lengths. 31-33.5 35-36.5 37-39.5 175.00 a set. If you are replacing stock 30 spline D60 axles your spindle will have to be reamed out. And please measure your hub mounting bolt pattern before you order, these measure 8x3.96". These will make your wimpy stock 30 spline shafts look like babies.
![]() ![]() ![]() www.fourwheelsupply.net fourwheelsupply@yahoo.com |
Member # 21282
do these neck down at any point? or are they a full 1.5" the entire length?
can they be made with 14 bolt outer flange bolt pattern? can you make a 20" shaft? What kind of warranty? |
Member # 48583
I can get blanks that are 1.51" for 35 spline and they are non drilled. They will cost you 150$ a pair. I am checking on the machine work cost. and I will get back to you. thanks BUTCH
Member # 23262
Are these all 3 31/32" bolt circle on the flange? Can anything be had over 40" in length?
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools. --Herbert Spencer, English Philosopher (1820-1903) |
#8 (permalink) | |
Member # 37244
#10 (permalink) | |
Member # 37244
Member # 48583
By that measurement I will say that your axles will be in the 34-36.5 range, so that would be the ones I would recomend, and they do have the recess machined to clear the spindle. Thanks Butch
#13 (permalink) |
Member # 48583
If you want to use a credit card paypal is the only way right now I can do that, I am in the process of having my web page set up as a e-commerce and accept credit cards direct, but it hasnt went through yet. So other than paypal you can send me a certified check or money order.
#20 (permalink) |
Member # 21282
did you find out about my custom shafts?
14 bolt ends and 35 spline email me at twsnider@hotmail.com |
