Member # 19787
CCT Differential Breather System
We have picked a new item from a local vendor. This a sweet Differential Breather System. Basically plug and play. If you put your diffs in the crap, let them breathe.
This Breather system is a brand new product on the market. It is built by CCT Breathers, a company that is located here in the Northwest. The system comes with everything pictured. It allows a highly flexible coil hose to connect to your factory diff. breather hole. All lines connect with push-and-lock style connectors that will not come apart. The actual breather mounts where ever you want it. (High on the firewall is recommended.) This is the easiest kit we have ever installed. $80.00 give us a call to place your order or have us answer questions. 360-567-3347 |
