Member # 1088
~~~TOYOTA Solid pinion spacers, ditch that crush sleeve!~~~
Getting rid of, or rather, not installing a crush sleeve in your diff keeps pinion bearing preload constant. This prevents loosening of the pinion, causing gear failure. Also, with a crush sleeve, you can change a pinion seal WITHOUT pulling the diff, or worrying about changing gear pattern at all.
V6 diff spacer with shims $25 4cyl spacer with shims $25
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 /forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html |
