GLO DIY Competition B-locks All Sizes $180 4A set of 4
15" 16" 16.5" 17" and others $180 plus shipping for the laser cut 1/4" thick steel rings to turn 4 of your wheels to beadlocks this is a limited time offer. These are the original design that sits just inside the wheel lip that prevents the outer bead from being dented in, unlike the designs where the ring is flush to the outside and can give in. We are also selling the hardware for $10 per wheel and offering an anti coning material now that can be inserted into the beadlock for $10 per wheel. The anti coning ring is made of a new space age material that is resistent to oil/chemicals and sunlight. It is NOT a steel ring as these deflect the amount or grip you can apply to a rubber tire. Steel anti coning ring designs can and will leak. Our rings feature 32 bolt holes 3/8" diameter. Once you get to 17" wheels and up we increase the amount of bolts used in order to keep ample amount of pressure on the tire. We can supply these in any form or combination you like. Please e-mail me for a quote and realize these are the same locks you guys have been buying for the past several years so the same quality is there. Thanks Shawn
http://www.greatlakeoffroad.com Don't Forget Your Discount enter Pirate10 to get your 10% discount off |
We now also offer a tire center ring that gets welded to the inner ring to center the tire during install for a nominal fee. This eliminates the need for multiply hands during the bolt tightening process. Thanks Shawn
We are also looking into tapping the inner ring as an option if you guys show interest. Thanks Shawn
bump
bump
bump
#7 (permalink) | |
'93 YJ 4Banger |
Member # 41137
how resistant is the space age material to abuse?
[QUOTE=climbit;14733286]you guys take this shit way too seriously.[/QUOTE] |
#11 (permalink) | |
We have only done one set so far w/ the recenter ring and those shipped out ASAP for a customer I will get some cut this weekend and gets some new pics I will also try and get a pic of the material sandwiched between the rings for you. Thanks Shawn
#12 (permalink) | |
Not as of yet but we're still tryting to find a reasonable outlet for these for you guys. Thanks Shawn
#13 (permalink) | |
Its marine grade so its resistent to chemicals, oil, UV and moisture. As far as abuse it sits between two steel rings so its not really going to see any direct contact to rocks etc. Thanks Shawn
#14 (permalink) | |
You have an e-mail quote. Thanks Shawn
#15 (permalink) |
bump
#16 (permalink) |
Everyone has e-mail quotes. Thanks Shawn
#17 (permalink) |
All that have paid for parts are shipping monday, Thanks Shawn
#19 (permalink) |
ttt
#22 (permalink) |
Member # 2086
would i be able to get 4 of the steel inner rings fo 17 inch wheels. the reason i ask is i want to do some kind of custom aluminum outer rings. price shipped to 95472
thanks sean
i hate it when the alcohol and peer pressure kicks in about the same time ====okiE inJunEered==== |
#23 (permalink) | |
I need an e-mail address to send you a quote. Thanks Shawn
#24 (permalink) | |
#25 (permalink) | |
