Member # 1088
Diamond Axle's new housing ends!! Toy and D60!
These ends are some of the ones we are using on our housings. Recently we've decided to start offering just the housing ends, for talented DIY folks, and well setup shops!
First up, is Dana 60 Full Float housing ends. These are machined from 1" thick billet 1018 steel, in house! The spindle bore, spindle mount face, holes, threads and tube bore are machined in the same setup to ensure PERFECT alignment. We've been making this style of end for more than a decade! Then when Dustin (Red Bull Rockcrawling fame) wanted the lightest, and strongest axles possible, we took to scalloping the outside. The result is what you see, and what you get! We're stocking 3.5" tube bored ends, and 3" tube ends.
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 /forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html Last edited by Brian Ellinger; 01-18-2012 at 02:42 PM. |
Member # 1088
EDIT: Old style D60 Full Float end. This flange simply accepts a stock chevy front D60 spindle, allowing for a 35 spline, Full-Float axle assembly, with easily replaceable spindles. And of course, machined so it presses onto the tubing, no butt welding here!
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 Last edited by Brian Ellinger; 08-25-2011 at 03:29 PM. |
Member # 1088
First shown is our older style Toyota Full Float ends.
Check out the new ones, with the caliper mount machined as one piece! We've been doing bolt-on Full-Float axle kits for the Toy minis since dirt was new. Now we're simply combining the stock housing end, and our Full-Float rings onto the housings. And of course, these ends, like all the rest, press onto the axle tubes for strength! Also sold per pair, with the caliper mounts. Caliper mounts work for stock solid axle brakes, or 86-95 truck calipers and FJ40/60 rotors. Doing something else? just put the caliper ears towards the front of the axle, and mount whatever you'd like on the backside!
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 Last edited by Brian Ellinger; 12-20-2011 at 08:17 AM. |
Member # 1088
space saved
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 Last edited by Brian Ellinger; 08-24-2011 at 04:50 PM. |
Member # 1088
They are made to fit the 3.5" tubing.
They are shown loose, because they photograph better this way. Sorry for the confusion guys. We do have bolt-on Full-Float kits for the Toy rear ends currently.
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 |
Member # 1088
Give me a call, or PM
Earl Dibbles Jr.
Member # 13126
What would you get for some ends for a 12 bolt, using D44 outers?
Trade for Chevy D44 Fr Alloy shafts, FF 14 bolt detroit or simaler locker, Dana 44 Hight steer arms, air shocks or coil overs |
#13 (permalink) | |
Member # 1088
#16 (permalink) |
pissnmetal
How much for a rear 9" housing w/ the FF flanges with a target of 67" WMS?
BlackOut Autosports Offroad & Performance Fabrication Click Here For Awesome Metal Fabrication Equipment From BAILEIGH INDUSTRIAL |
#17 (permalink) | |
Member # 1088
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 Last edited by Brian Ellinger; 08-24-2011 at 04:52 PM. |
#19 (permalink) |
Member # 5326
I know its not what you where looking at to begin with.....but I think a flange that would allow a D60 spindle and brake bracket to be bolted on would be a great idea as a seperate part.
42 MB, 225, T18, big kid go cart with clown tires 92 Dodge W250 daily driver on 39s |
#20 (permalink) |
Member # 1088
Now releasing these due to request!
#21 (permalink) |
Member # 1088
Stocking 3" and 3.5" bore, and can do others upon request!
#22 (permalink) |
Member # 1088
In stock!
#24 (permalink) |
Member # 1088
Yes! Design on those ends is done, very similar to the other 60 ends, and will end up the same price. I think we'll have them done next week! What tube size are you looking for, and I'll set a pair aside for you!
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 Last edited by Brian Ellinger; 08-31-2011 at 07:56 AM. |
#25 (permalink) |
Member # 1088
in stock
