OK, maybe this time! Dana 60 Razorback - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 02-01-2006, 06:11 AM   #1 (permalink)
DIY4X's Avatar
Member # 63837
Dana 60 Razorback
Seems I'm not very good at posting in here so we'll give it another shot.
The left one is a front cover with Tie rod clearance and clears a 1.5" Tie rod.
The right one is a rear cover or could be used with High steer.
These are $155 plus shipping and includes the hardware. Grade 8 serrated flange bolts and a brass hex key plug.
Here's a shot of the matching piece for the 14BFF.
We have had enormous amount of requests for Drain plugs and fill plugs.I really didn't want to put them in but, If you want a drain plug I will put it in for you. Call to order these until we can figure out how it will be added to the website. There is a $10.00 charge per port for adding plugs.
DIY4X is offline   Reply With Quote
Old 11-16-2009, 05:32 AM   #2 (permalink)
DIY4X's Avatar
Member # 63837
Razorbacks!
SUPPORT THE BLUE RIBBON COALITION!!!!
Specialty off road shop. In house fabrication for just about anything you might need.
SAS Kit coming soon!
712-472-0200 Order line
712-479-2252 Tech support
www.diy4x.com
Old 04-24-2013, 05:57 AM   #3 (permalink)
DIY4X's Avatar
Member # 63837
In stock and ready to weld.
www.diy4x.com
